Lost with layout methods and parameters... [message #1138959] |
Tue, 15 October 2013 12:44 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
hortiz Mising name![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=helene.chagnot%40gmail.com) Messages: 96 Registered: July 2009 |
Member |
The javadoc says about the layout method with two boolean parameters that if the second argument is set to true "the layout will cascade down through all child widgets in the receiver's widget tree, regardless of whether the child has changed size".
So I do not understand why in my snippet a click on the "Layout shell" button does not trigger any layout method of MyComposite instance whereas a click on the "Layout composite" button does...
package benchmark;
import org.eclipse.swt.SWT;
import org.eclipse.swt.events.SelectionAdapter;
import org.eclipse.swt.events.SelectionEvent;
import org.eclipse.swt.layout.GridData;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.widgets.Shell;
public class TestLayoutShell {
private Shell shell;
private MyComposite composite;
public static void main (String[] args) {
TestLayoutShell test = new TestLayoutShell();
test.run();
private void run() {
Display display = new Display();
shell = new Shell(display);
shell.setLayout(new GridLayout(3, false));
composite = new MyComposite(shell, SWT.BORDER);
composite.setLayoutData(new GridData(100, 100));
Button layoutButton = new Button(shell, SWT.PUSH);
layoutButton.setText("Layout shell");
layoutButton.addSelectionListener(new SelectionAdapter() {
public void widgetSelected(SelectionEvent arg0) {
shell.layout(true, true);
Button layout2Button = new Button(shell, SWT.PUSH);
layout2Button.setText("Layout composite");
layout2Button.addSelectionListener(new SelectionAdapter() {
composite.layout(true, true);
shell.open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch()) {
display.sleep();
display.dispose();
package benchmark;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Control;
public class MyComposite extends Composite {
public MyComposite(Composite parent, int style) {
super(parent, style);
public void layout() {
super.layout();
System.out.println("layout()");
public void layout(boolean arg0, boolean arg1) {
super.layout(arg0, arg1);
System.out.println("layout(boolean arg0, boolean arg1)");
public void layout(boolean arg0) {
super.layout(arg0);
System.out.println("layout(boolean arg0)");
public void layout(Control[] arg0, int arg1) {
System.out.println("layout(Control[] arg0, int arg1)");
public void layout(Control[] arg0) {
super.layout(arg0);
System.out.println("layout(Control[] arg0)");
Thanks in advance for your help,
Helene
FUDForum. Page generated in 0.03460 seconds
