Unable to launch executable generated by Eclipse - error 193 [message #1109885] |
Mon, 16 September 2013 04:47 |
Huzefa Hakimi Messages: 2 Registered: September 2013 |
I am trying to compile and run simple c++ program using Eclipse with Cygwin as toolchain but I am running into issues (first try with Eclipse for C++). Help with the issue with the issue covered is appreciated.
Details:
Build of program goes fine but when I start program (named Project) in Debug (Run --> Debug) in debug mode or even run it (Run -->Run), I get error "'Launching Project.exe' has encountered a problem".
Details of error:
Error in final launch sequence
Failed to execute MI command:
-exec-run
Error message from debugger back end:
Error creating process /cygdrive/c/Users/Genius/workspace/Project/Debug/Project.exe, (error 193).
Could I be missing something in configuration?
Initially my workspace was on E:\ (E:\Users\Genius\workspace\) than C:\ - primary Windows partition on which Windows 7 is installed. This where I was initially seeing errors.
-exec-run
Error creating process /cygdrive/e/Users/Genius/workspace/Project/Debug/Project.exe, (error 193).
While searching over this issue, I had came across posts in different forums stating Launch of program failed as it had issues with permissions and better to have workspace in primary partition (not sure why?). To square out that I copied over workspace contents to C:\ (C:\Users\Genius\workspace\) but that also did not help.
-exec-run
There are no spaces in the path.
From cygwin prompt, I can compile, debug and run program fine. So I have feeling there could be some settings my project would be missing.
Installed package information in cygwin for C/C++ environment
$ cygcheck.exe -c
Cygwin Package Information
Package Version Status
cccc 3.1.4-1 OK
cgdb 0.6.6-1 OK
coreutils 8.15-1 OK
cygutils 1.4.14-1 OK
cygwin 1.7.25-1 OK
gcc 4.7.3-1 OK
gcc-core 4.7.3-1 OK
gcc-g++ 4.7.3-1 OK
gdb 7.6.50-4 OK
make 3.82.90-1 OK
Running program in gdb on cygwin prompt the one generated by cygwin runs fine:
Genius@Genius-PC /cygdrive/e/Users/Genius/workspace/Project/src
$ gdb.exe a.exe
GNU gdb (GDB) 7.6.50.20130728-cvs (cygwin-special)
Copyright (C) 2013 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <gnu linked removed>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law. Type "show copying"
and "show warranty" for details.
This GDB was configured as "i686-pc-cygwin".
Type "show configuration" for configuration details.
For bug reporting instructions, please see:
<-- removed gnu link -->
Find the GDB manual and other documentation resources online at:
<-- edited: removed gnu link -->
For help, type "help".
Type "apropos word" to search for commands related to "word".
Reading symbols from /cygdrive/e/Users/Genius/workspace/Project/src/a.exe...done.
(gdb) start
Temporary breakpoint 1 at 0x4012dd
Starting program: /cygdrive/e/Users/Genius/workspace/Project/src/a.exe
[New Thread 6880.0xc40]
[New Thread 6880.0x2064]
Temporary breakpoint 1, 0x004012dd in main ()
(gdb) continue
Continuing.
#1 Move disk 2 from 1 to 3.
#1 Move disk 1 from 1 to 2.
#2 Move disk 1 from 1 to 2.
#2 Move disk 2 from 1 to 3.
#1 Move disk 1 from 2 to 3.
#2 Move disk 1 from 2 to 3.
[Inferior 1 (process 6880) exited normally]
But when I try to load the executable in gdb generated by Eclipse, I see the same on cygwin also:
$ gdb.exe Project.exe
License GPLv3+: GNU GPL version 3 or later <link removed>
<link removed>.
<link removed>.
Reading symbols from /cygdrive/c/Users/Genius/workspace/Project/Debug/Project.exe...done.
(gdb) start
Temporary breakpoint 1 at 0x64b81258: file ../src/Project.cpp, line 33.
Starting program: /cygdrive/c/Users/Genius/workspace/Project/Debug/Project.exe
(gdb)
I have explicitly set path and symbols (PathAndSymbols.png) as well as Path Mapping (PathMapping.png) for Cywin in Eclipse. Files for same are attached with this post.
Help to resolve above is highly appreciated.
Re: Unable to launch executable generated by Eclipse - error 193 [message #1111297 is a reply to message #1110693] |
Wed, 18 September 2013 03:19 |
Axel Mueller wrote on Tue, 17 September 2013 03:38Error 193 means that Project.exe is not a valid executable. There seems something wrong with your compiler settings. In this thread link removed a similar problem was reported. See second answer.
Thanks Axel, that did the trick, now atleast program starts in debugger. In addition I installed mingw-core and mingw-g++ packages available for cygwin.
Though the next issue I am running into is being not able to Debugger perspective is not able. When I run the program as Debug, it launches Debug perspective but than I see message "No source available for "ntdll!ZwReadFile() at 0x7786f905" and due to this breakpoints and stepping through code in Debugger perspective is not operational at present. Will try to look around for this issue. In case if you know how to resolve pls let me know.
Thnxs
Update: The above problem "No source available for "ntdll!ZwReadFile() at 0x7786f905" went away. Had to clean Debug Configuration. Deleted the earlier generated listing of Project.exe and performed clean build again and this time it went fine. Only issue was during exit, it seems its displaying the message as below. Not sure if that's an issue or not.
[Updated on: Wed, 18 September 2013 03:32] Report message to a moderator
FUDForum. Page generated in 0.03031 seconds
