Re: no tree is shown for the outline [message #1088292 is a reply to message #1088113] |
Fri, 16 August 2013 22:05 |
Jeremie Bresson Messages: 1252 Registered: October 2011 |
Scout proposes different types of applications. Are you sure you have created an "Outline based application" ?
Can you post here the content of <your app>.client.ui.desktop.Desktop#execOpened()
For a desktop based application it should looks like:
protected void execOpened() throws ProcessingException {
//If it is a mobile or tablet device, the DesktopExtension in the mobile plugin takes care of starting the correct forms.
if (!UserAgentUtility.isDesktopDevice()) {
return;
// outline tree
DefaultOutlineTreeForm treeForm = new DefaultOutlineTreeForm();
treeForm.setIconId(Icons.VCard);
treeForm.startView();
//outline table
DefaultOutlineTableForm tableForm = new DefaultOutlineTableForm();
tableForm.setIconId(Icons.VCard);
tableForm.startView();
if (getAvailableOutlines().length > 0) {
setOutline(getAvailableOutlines()[0]);
Can you also compare with the swing rendering of the same application? Do you see the page tree or not?
Have you checked your console output?
[Updated on: Fri, 16 August 2013 22:07] Report message to a moderator
FUDForum. Page generated in 0.02457 seconds
