SWT: Switching between SearchForm/TableForm-Pairs does not work [message #1053341] |
Sat, 04 May 2013 06:38 |
Volkert B. Messages: 12 Registered: June 2012 |
Dear all.
switching between SearchForm/TableForm-Pairs seems not to work in an SWT-Client.
You can reproduce it with the MiniCRM-Example
If you select "Company" in the StandardTreeView the CompanySearchForm is displayed together with its CompanyTablePage. That is correct.
If you select "Person" in the StandardTreeView the PersonSearchForm is not displayed, only its PersonTablePage. It looks like an bug here (refreshing problem?)
Everything works as expected in the Swing-Client.
Can someone reproduce this behaviour? If so, i can open a new bug ticket.
BW,
Volkert
Eclipse Juno SR2 / Scout 3.8.2
Windows 7 SP1
Java 1.7.0_21
[Updated on: Mon, 06 May 2013 04:12] Report message to a moderator
FUDForum. Page generated in 0.04769 seconds
