Home » Modeling » ATL » foreach
foreach [message #1038837] Thu, 11 April 2013 08:03 Go to next message
samar sousou is currently offline samar sousou
Member
hi,
why the distinct and the foreach don't work!! there is a plug in not installed!!
my rule is :
rule EnumColumn {
from
i : XML!Element (
if i.name = 'TableInfoTable'
then
i.getFirstElementByName('Type').getTextValue().startsWith('enum')
else
false
endif
using {
items : Sequence(String) =
i.getFirstElementByName('Type').getTextValue().getItemList();
to
o : MySQL!EnumColumn (
name <- i.getFirstElementByName('Field').getTextValue(),
type <- 'enum',
isPrimaryKey <-
i.getFirstElementByName('Key').getTextValue() = 'PRI',
null <- i.getFirstElementByName('Null').getTextValue() = 'YES',
defaultValue <- i.getFirstElementByName('Default').getTextValue(),
comment <- i.getFirstElementByName('Comment').getTextValue(),
table <- i.parent,
enumSet <- e1
e1 : MySQL!EnumSet (
enumItems <- e2
e2 : distinct MySQL!EnumItem foreach(i in items) (
name <- i,
enumSet <- e1
the error was:
distinct-foreach target pattern elements are deprecated, use lazy rules instead
but how can I do the lazy rule!!
I tried but there is a problem all the time :'(
I need your help.
thank you.
Re: foreach [message #1048266 is a reply to message #1038837] Wed, 24 April 2013 04:33 Go to previous message
Ronan B is currently online Ronan B
Collect the values from MySQL!EnumItem and call a lazy rule for each element in the list.
Ronan
Previous Topic:serialisation
Next Topic:Cannot find class in reference model
Current Time: Tue May 28 09:37:52 EDT 2013
Powered by FUDForum. Page generated in 0.01526 seconds
