Home » Eclipse Projects » Eclipse 4 » AbstractCSSEngine MalFormedURLException in a deployed RCP product
AbstractCSSEngine MalFormedURLException in a deployed RCP product [message #1016153] Tue, 05 March 2013 09:33
Quang Tran is currently offline Quang TranFriend
Hi guys,
we had an RCP Product based on 4.1 using the compatibility layer. After switching the target platform to 4.2.2 the theming via css didn't work anymore on a deployed product, it only works in the IDE. Ater looking at the code in AbstractCSSEngine we found a change since 4.1
4.1:
URL url = FileLocator.resolve(new URL(trim.addTrailingSeparator().toString() + ((CSSImportRule) rule).getHref()));
InputStream stream = url.openStream();
4.2.2
File testFile = new File(url.getFile());
if (!testFile.exists()) {
  //look in platform default
  String path = getResourcesLocatorManager().resolve(((CSSImportRule) rule).getHref());
  testFile = new File(new URL(path).getFile());
  if (testFile.exists()) {
    url = new URL(path);
This won't work if the file is in a deployed bundle.
We are using the "org.eclipse.e4.ui.css.swt.theme" extension point in our product
<extension
        point="org.eclipse.e4.ui.css.swt.theme">
     <theme
           basestylesheeturi="css/e4_day.css"
           id="default"
           label="%Theme_Default">
     </theme>
     <theme
           basestylesheeturi="css/e4_dark.css"
           id="dark"
           label="%Theme_dark">
     </theme>
  </extension>
Is this a known bug?
[Updated on: Tue, 05 March 2013 09:35]
Report message to a moderator
Previous Topic:Switching Themes in E3 mode
Next Topic:Running Juno to generate RCP e3
Current Time: Sat Apr 27 10:55:01 GMT 2024
Powered by FUDForum. Page generated in 0.03224 seconds
