Re: [xcore][xtend] ordering problem during clean build [message #997980 is a reply to message #997767] |
Wed, 09 January 2013 05:29 |
Ed Merks Messages: 33147 Registered: July 2009 |
Nicolas,
Comments below.
On 08/01/2013 6:46 PM, Nicolas Cabanis wrote:
> Hello,
> I have a project that contains several xcore files and several xtend
> files. The xtend files depend on code that is generated through the
> xcore files. During a clean build, all generated code gets deleted
> (xcore-generated as well as xtend-generated). The problem now is that
> xtend files depending on xcore-generated do not get generated.
Which versions are you using? I know there was a problem similar to
this, i.e., cleaning two mutually dependent Xcore models and Xcore
models that depend on Java source that depends on that Xcore model's
generated results. Also
https://bugs.eclipse.org/bugs/show_bug.cgi?id=394122 was fixed. So
maybe this isn't a problem in the latest builds...
> Is there a way of ordering the build?
No, I doubt that. They both register via dependency injection with the
Xtext builder framework via the org.eclipse.xtext.ui.shared.xtextBuilder
in the .project file.
> I gues not as both is done through the Xtext-Builder.
Exactly.
If it's a problem with the latest builds (which is probably not the case
with the fix for 394122 and with the improvements to the JvmInferrers
since the Xcore 1.1 stream), please open a minimal test case so the two
teams can have a look.
> Regards
> Nicolas
Ed Merks
FUDForum. Page generated in 0.02847 seconds
