Re: Row numbers for crosstab in a table [message #986854 is a reply to message #986652] |
Thu, 22 November 2012 04:14 |
You're wanting to have a running count on the rows in each crosstab, 1-n? Or a running count on the embedded crosstabs? Can you make an example with the sample database that shows the problem you're having? You should be able to simply increment a variable in a dynamic text box or something, but maybe I'm misunderstanding.
Michael
Developer Evangelist, Silanis
Re: Row numbers for crosstab in a table [message #987160 is a reply to message #986860] |
Fri, 23 November 2012 22:02 |
Try this: In the initialize event, put something like rCount=0; Then, in the onCreate of the outer table's row, where the crosstab is embedded, put the same. Finally, in a dynamic text box, in your crosstab dimension area, increment rCount and display it. This should cause the rCount variable to increment for each row, then to reset for each new outer table group. Let me know.
Michael
FUDForum. Page generated in 0.05633 seconds
