Error with Plug in Tutorial [message #142283] |
Wed, 08 March 2006 21:19 |
Originally posted by: ffoozle.hotmail.com
Is there an error with the Eclipse Plug-in tutorial under Eclipse 3.1.1?
I am getting the following error:
Error 2006-03-08 16:18:54.356 Error saving state file for the
'org.eclipse.pde.helloworld' cheat sheet.
javax.xml.transform.TransformerException: java.io.FileNotFoundException:
file:\C:\Test\.metadata\.plugins\org.eclipse.ui.cheatsheets\ org.eclipse.pde.helloworld.xml
(The filename, directory name, or volume label syntax is incorrect)
org.apache.xalan.transformer.TransformerIdentityImpl.createR esultContentHandler(TransformerIdentityImpl.java:263)
org.apache.xalan.transformer.TransformerIdentityImpl.transfo rm(TransformerIdentityImpl.java:296)
org.eclipse.ui.internal.cheatsheets.data.CheatSheetSaveHelpe r.saveState(CheatSheetSaveHelper.java:403)
org.eclipse.ui.internal.cheatsheets.data.CheatSheetSaveHelpe r.saveState(CheatSheetSaveHelper.java:419)
org.eclipse.ui.internal.cheatsheets.views.CheatSheetViewer.s aveCurrentSheet(CheatSheetViewer.java:799)
org.eclipse.ui.internal.cheatsheets.views.CheatSheetViewer.a dvanceIntroItem(CheatSheetViewer.java:151)
org.eclipse.ui.internal.cheatsheets.views.IntroItem$1.linkAc tivated(IntroItem.java:71)
org.eclipse.ui.forms.widgets.AbstractHyperlink.handleActivat e(AbstractHyperlink.java:209)
org.eclipse.ui.forms.widgets.ImageHyperlink.handleActivate(I mageHyperlink.java:174)
org.eclipse.ui.forms.widgets.AbstractHyperlink.handleMouseUp (AbstractHyperlink.java:299)
org.eclipse.ui.forms.widgets.AbstractHyperlink.access$1(Abst ractHyperlink.java:283)
org.eclipse.ui.forms.widgets.AbstractHyperlink$4.handleEvent (AbstractHyperlink.java:111)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3080)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2713)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Caused by: java.io.FileNotFoundException:
at java.io.FileOutputStream.open(Native Method)
at java.io.FileOutputStream.<init>(Unknown Source)
org.apache.xalan.transformer.TransformerIdentityImpl.createR esultContentHandler(TransformerIdentityImpl.java:253)
... 31 more
FUDForum. Page generated in 0.07763 seconds
