Re: Using COM via JNI leads to class not registered exception [message #135672 is a reply to message #135570] |
Thu, 16 July 2009 12:43 |
Originally posted by: dleskov.excelsior-usa.com
I recall it may have something to do with threads, that is, when
initialization and usage occur in different threads. Sorry I do not have
more detail.
Dmitry
On Mon, 13 Jul 2009 14:16:52 +0700, Tobias Koetter
<tobias.koetter@gmx.net> wrote:
> I'm using com4j to use a COM dll written in C# from java. Using the COM
> interface in the main method of a java application works. If I'm using
> the same com4j methods in an eclipse plugin the following exception in
> the native C++ code of the com4j dll occurs: "80040154 CoCreateInstance
> failed : Class not registered" (com4j.cpp line 135).
> What I have tryed so far:
> Using the C# COM interface in a java main class using com4j->works
> Using other existing COM interfaces written in C++ via com4j in an
> eclipse plugin->works
> Placing the dll that implements the COM interface in the root path of
> the plugin-> does not work
> Using Bundle-NativeCode in the manifest to include the com4j and COM
> interface dll-> does not work
> I have also tryed another java<->com bridge JACOB that showed the same
> behaviour. Works in a java main but not in an eclipse plugin.
> Why does it work in a java application but not in an eclipse plugin?
> What is the differences using jni in a java application and in an
> eclipse plugin? Why does the com4j native code finds the COM interface
> in the registry and the eclipse plugin does not?
> Thanks a lot for your help!
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
FUDForum. Page generated in 0.02628 seconds
