Home » Newcomers » Newcomers » Can't run /usr/bin/ command in Eclipse java application?
Can't run /usr/bin/ command in Eclipse java application? [message #931952] Wed, 03 October 2012 13:30 Go to next message
Missing name Missing name is currently offline Missing name Missing name
Hello, I am developing a Java application in Eclipse on Mac Pro, similar to Linux environment.
In my code I need to do something like:
Runtime rt = Runtime.getRuntime();
String cmd = "ttg " + inFileName + " -o" + outFileName;
"ttg" is installed under /usr/bin and can be executed in a terminal, but can't be executed here in Eclipse. I have to specify the full path:
String cmd = "/usr/bin/ttg " + inFileName + " -o" + outFileName;
Under Windows, we can set this through Environment Variables. why the application in Eclipse can't call "ttg" without specifying the full path?
Any way out? Thanks.
[Updated on: Wed, 03 October 2012 13:31]
Report message to a moderator
Re: Can't run /usr/bin/ command in Eclipse java application? [message #941487 is a reply to message #931952] Fri, 12 October 2012 11:20 Go to previous message
Paul Webster is currently offline Paul Webster
Eclipse is probably not launched with the full path available to you at the shell. You'll have to investigate your mac environment to understand if mac does this or not.
PW
Previous Topic:Cannot get eclipse to run.
Next Topic:JRE or JDK?
Current Time: Sun May 19 08:24:33 EDT 2013
Powered by FUDForum. Page generated in 0.02375 seconds
