Re: versions of compilers used for the Agent Controller prebuild libs [message #123652 is a reply to message #123624] |
Thu, 21 February 2008 12:01 |
Asaf Yaffe Messages: 333 Registered: July 2009 |
exquisitus wrote:
> Hello,
> it seems that the gcc and msvs compilers
> used for building the libraries are older
> ones (below 3.1 and vs8). Maybe there
> is reasons for that, but in our case it
> would be nice to have the prebuild stuff
> with newer compilers (like the gcc
> 4.something and msvs 8).
> Regards
> Jochen
Agent Controller and related libraries (e.g., Java Profiler) are indeed
compiled using old compilers (VS6 for Windows, GCC 2.96 or 3.2 for
Linux). The main reason is compatibility with dependent libraries and
build environments of most TPTP committers. If you need to generate
binaries with newer compilers, please download the source code (that's
the beauty of being open-sourced!) and follow the build instructions in
the relevant readme files. Note, however, that AC has many dependencies
so it may not be a straightforward process.
If you have any specific questions regarding building AC and other libs,
please post them here and we'll try to help.
Asaf
Asaf Yaffe
Eclipse TPTP Committer, JVMTI Profiler
Re: versions of compilers used for the Agent Controller prebuild libs [message #123689 is a reply to message #123652] |
Thu, 21 February 2008 14:48 |
Joachim Haensel Messages: 10 Registered: July 2009 |
> Regards,
> Asaf
OK,
so we actually compiled the CVS files with VS8 and GCC 4.1 and it
works more or less fine (for VS8 we needed to write the .sln file
and for GCC we had to fix Bug 213360). The only "old" stuff we
had to use was Java 1.5 instead of 1.6 (because of the profiler
issue you mentioned).
Jochen.
FUDForum. Page generated in 0.03550 seconds
