Re: Declarative Services in an Eclipse Application [message #122619 is a reply to message #122609] |
Mon, 15 December 2008 09:40 |
Thomas Schindl Messages: 6651 Registered: July 2009 |
I've written an example application some time ago where I also show how
to use DS.
The sources are available here [1].
The things you are interested in are:
- Starting ds when applications starts [2] - this could also be done in
a customized config.ini of course
- Declaration of the DS [3,4,5]
- Accessing the DS [6,7,8,9]
Tom
[1] http://publicsvn.bestsolution.at/repos/java/examples/EMF-Dat abinding/
[2] http://publicsvn.bestsolution.at/repos/java/examples/EMF-Dat abinding/at.bestsolution.soccer.app/src/at/bestsolution/socc er/app/intro/Application.java
[3] http://publicsvn.bestsolution.at/repos/java/examples/EMF-Dat abinding/at.bestsolution.soccer.ui/OSGI-INF/
[4] http://publicsvn.bestsolution.at/repos/java/examples/EMF-Dat abinding/at.bestsolution.soccer.ui/src/at/bestsolution/socce r/ui/IImageStorage.java
[5] http://publicsvn.bestsolution.at/repos/java/examples/EMF-Dat abinding/at.bestsolution.soccer.ui/src/at/bestsolution/socce r/ui/internal/ImageStorageImpl.java
[6] http://publicsvn.bestsolution.at/repos/java/examples/EMF-Dat abinding/at.bestsolution.soccer.ui.playeradmin/src/at/bestso lution/soccer/ui/playeradmin/Activator.java
[7] http://publicsvn.bestsolution.at/repos/java/examples/EMF-Dat abinding/at.bestsolution.soccer.ui.playeradmin/src/at/bestso lution/soccer/ui/playeradmin/PlayerAdministrationDialog.java
[8] http://publicsvn.bestsolution.at/repos/java/examples/EMF-Dat abinding/at.bestsolution.soccer.ui.associationteamadmin/src/ at/bestsolution/soccer/ui/associationteamadmin/Activator.jav a
[9] http://publicsvn.bestsolution.at/repos/java/examples/EMF-Dat abinding/at.bestsolution.soccer.ui.associationteamadmin/src/ at/bestsolution/soccer/ui/associationteamadmin/TeamAdministr ationForm.java
Alexis R. schrieb:
> Hello!
> I have a bit of a more general question than most. I am new to this OSGi
> Services thing, but I have allready seen some aspects of a project I am
> working on, that would be conceptionaly better if they where defined as
> a Declarative Service. For a couple of days I have been trying to
> figure out how to use Declarative Services for an Eclipse Plugin. I have
> been able to launch my example code as an OSGi framework but how will I
> go about launching the same code from a plugin? I have a component that
> offers a service implementing an interface. Let's say the service has
> the name "ServiceA" :) Now I have my Eclipse Plug-In code and I would
> like to use this "ServiceA" everytime the user selection an Action from
> a menu. What is the correct was of doing this? A very first problem I am
> facing is how do I launch my eclipse-launch-configuration with
> declarative services included? For the OSGi launch one needs to add the
> org.eclipse.equniox.ds bundle. But how do I do the analog thing for my
> eclipse-launch-configuration? I found some wiki page for using DS with a
> RCP and that should be fundamentaly the same but following the
> instructions ( edditing the config.ini file ) didn't bring the desired
> results. Can somebody point me to the right direction?
> Thank you for reading this far and thank you for your time!
> Greetings,
> Alexis
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: Declarative Services in an Eclipse Application [message #123047 is a reply to message #123035] |
Tue, 16 December 2008 15:27 |
Originally posted by: ekkehard.gentz-software.de
if you type
services
in your osgi console - is the service listed ?
Alexis R. schrieb:
> Hi!
> With our help I have written a very small plug-in that uses a service.
> Or I should say doesn't use. I have downloaded and installed the
> equinox.ds jar and the util jar. The starting of the
> org.eclipse.equinox.ds now works. But when I try to get a
> ServiceReference for my service I get a null.
> My OSGI-INF:
> <component immediate="true" name="com.ventuja.service">
> <implementation class="com.ventuja.service.implementation.Messenger"/>
> <service>
> <provide interface="com.ventuja.plugin.interfaces.IMessenger"/>
> </service>
> </component>
> Here is my code that I use to get the ServiceReference:
> public IMessenger getMessenger() {
> //gives a null
> ServiceReference ref =
> context.getServiceReference(IMessenger.class.getName());
> if( ref != null ) {
> return (IMessenger) context.getService(ref);
> return null;
> It is located in the Activator class of my plugin.
> Do I need to change something in my build files or something similar?
> I exported my example and have it here:
> http://www.ventuja.com/dsplugin.zip if anybody is interested in peeking
> into it:)
> Thanks you for reading!
> Alexis
Re: Declarative Services in an Eclipse Application [message #123071 is a reply to message #123035] |
Tue, 16 December 2008 20:34 |
I'd try launching from the Eclipse workspace first as an OSGi
application to eliminate other potential sources of problems. Make sure
that the build.properties includes the OSGI-INF folder.
Is the bundle containing the service started? I recently played with DS
and I recall that I had to start the bundles containing the service
components as well. Just starting the Equinox DS bundle wasn't enough.
But I haven't digged deeper to investigate the reason for this. My
previous assumption was that DS would start the bundles contributing
service components as necessary (similar to the extension registry). But
I haven't found clarification/confirmation in the spec yet.
-Gunnar
Gunnar Wagenknecht
gunnar@wagenknecht.org
http://wagenknecht.org/
Re: Declarative Services in an Eclipse Application [message #123110 is a reply to message #123035] |
Wed, 17 December 2008 07:34 |
Originally posted by: b.l.kelly.bigpond.com
The activation of the bundle occurs before DS looks for the service
component definitions, so it won't have published the service.
I think it is safest to always use another service component to access the
services published by a service component. If you use static binding then it
also takes less code as DS does all the work of tracking the service
availability.
"Alexis R." <alexis.raptarchis@googlemail.com> wrote in message
news:6989048d7baf599c0fff567d9738b4fc$1@www.eclipse.org...
> Hi!
> With our help I have written a very small plug-in that uses a service. Or
> I should say doesn't use. I have downloaded and installed the equinox.ds
> jar and the util jar. The starting of the org.eclipse.equinox.ds now
> works. But when I try to get a ServiceReference for my service I get a
> null.
> My OSGI-INF:
> <service>
> </service>
> </component>
> //gives a null
> if( ref != null ) {
> return null;
> into it:)
> Alexis
Re: Declarative Services in an Eclipse Application [message #123182 is a reply to message #123145] |
Wed, 17 December 2008 20:43 |
Alexis R. schrieb:
> services declared in the bundles. The simplest way of doing this is to use
> the startup extension-point from the bundles declaring the services. If
> that is a good idea in the long run is a different question but atleast it
> works this way.
The UI startup extension point? Uhh that's hackish. Anyway, I created
the concept of server roles in CloudFree. It is similar to the
application model but allows a more dynamic composition of bundles to be
started or stopped at runtime.
-Gunnar
Gunnar Wagenknecht
FUDForum. Page generated in 0.03747 seconds
