| question about how Listeners work [message #913022] |
Fri, 14 September 2012 12:02 |
ben agai Messages: 36 Registered: July 2012 |
Member |
hi, i want to ask about how the listeners in java work.
if a class that i created, in this case DocInfo, implements IDocumentListener interface, and a DocumentEvent has occoured, could it be that before the current DocumentEvent has finished the documentChanged(DocumentEvent event) function another DocumentEvent will occour and activate the documentChanged(DocumentEvent event) function simultaneously?
here is the code below, thanks.
package handlevent.handlers;
import org.eclipse.jface.text.DocumentEvent;
import org.eclipse.jface.text.IDocumentListener;
public class DocInfo implements IDocumentListener{
public void documentAboutToBeChanged(DocumentEvent event) {
// TODO Auto-generated method stub
public void documentChanged(DocumentEvent event) {
System.out.println("document has been changed:");
System.out.println(event.getText());
FUDForum. Page generated in 0.01360 seconds
