Home » Archived » BIRT » Error when generating the Birt report (BIRT)
Error when generating the Birt report [message #896926] |
Fri, 20 July 2012 13:07 |
BRAROU NABIL Messages: 3 Registered: July 2012 |
I am brand new to BIRT's world, i would like to generate a simple report wich contains a pie chart from a database that i have created.
I Have a Dataset called "commune" that contains a query which fetch by "code_commune" column.
The pie chart is created within another Dataset (Data_set1)for example.
In this last Dataset I put the following query in order to create my pie chart:
select distinct
1 as idCandidat, public.election.nom1 as nomCandidat,public.election.voix1 as voix from public.election where public.election.code_commune=?
UNION
select 2 as idCandidat, public.election.nom2 as nomCandidat,public.election.voix2 as voix from public.election where public.election.code_commune=?
UNION
select 3 as idCandidat, public.election.nom3 as nomCandidat,public.election.voix3 as voix from public.election where public.election.code_commune=?
UNION
select 4 as idCandidat, public.election.nom4 as nomCandidat,public.election.voix4 as voix from public.election where public.election.code_commune=?
UNION
select 5 as idCandidat, public.election.nom5 as nomCandidat,public.election.voix5 as voix from public.election where public.election.code_commune=?
UNION
select 6 as idCandidat, public.election.nom6 as nomCandidat,public.election.voix6 as voix from public.election where public.election.code_commune=?
UNION
select 7 as idCandidat, public.election.nom7 as nomCandidat,public.election.voix7 as voix from public.election where public.election.code_commune=?
UNION
select 8 as idCandidat, public.election.nom8 as nomCandidat,public.election.voix8 as voix from public.election where public.election.code_commune=?
UNION
select 9 as idCandidat, public.election.nom9 as nomCandidat,public.election.voix9 as voix from public.election where public.election.code_commune=?
UNION
select 10 as idCandidat, public.election.nom10 as nomCandidat,public.election.voix10 as voix from public.election where public.election.code_commune=?
But the problem is while previewing my report I got the following error.
The following items have errors:
Grid (id = 28):
+ A BIRT exception occurred. See next exception for more information.
Error evaluating Javascript expression. Script engine error: ReferenceError: "commune" n'est pas défini
Script source: unnamed script, line: 0, text:
commune (Element ID:28)
data.engine.BirtException ( 1 time(s) )
detail : org.eclipse.birt.report.engine.api.EngineException: A BIRT exception occurred. See next exception for more information.
at org.eclipse.birt.report.engine.executor.ExecutionContext.addException(ExecutionContext.java:1237)
at org.eclipse.birt.report.engine.executor.ExecutionContext.addException(ExecutionContext.java:1216)
at org.eclipse.birt.report.engine.executor.QueryItemExecutor.executeQuery(QueryItemExecutor.java:96)
at org.eclipse.birt.report.engine.executor.GridItemExecutor.execute(GridItemExecutor.java:65)
at org.eclipse.birt.report.engine.internal.executor.dup.SuppressDuplicateItemExecutor.execute(SuppressDuplicateItemExecutor.java:43)
at org.eclipse.birt.report.engine.internal.executor.wrap.WrappedReportItemExecutor.execute(WrappedReportItemExecutor.java:46)
at org.eclipse.birt.report.engine.internal.executor.l18n.LocalizedReportItemExecutor.execute(LocalizedReportItemExecutor.java:34)
at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:65)
at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout(HTMLPageLM.java:92)
at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutEngine.layout(HTMLReportLayoutEngine.java:100)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAndRenderTask.java:180)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run(RunAndRenderTask.java:77)
at org.eclipse.birt.report.service.ReportEngineService.runAndRenderReport(ReportEngineService.java:929)
at org.eclipse.birt.report.service.BirtViewerReportService.runAndRenderReport(BirtViewerReportService.java:973)
at org.eclipse.birt.report.service.actionhandler.BirtGetPageAllActionHandler.__execute(BirtGetPageAllActionHandler.java:131)
at org.eclipse.birt.report.service.actionhandler.AbstractBaseActionHandler.execute(AbstractBaseActionHandler.java:90)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseDocumentProcessor.__executeAction(AbstractBaseDocumentProcessor.java:47)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseComponentProcessor.executeAction(AbstractBaseComponentProcessor.java:143)
at org.eclipse.birt.report.soapengine.processor.BirtDocumentProcessor.handleGetPageAll(BirtDocumentProcessor.java:183)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:601)
at org.eclipse.birt.report.soapengine.processor.AbstractBaseComponentProcessor.process(AbstractBaseComponentProcessor.java:112)
at org.eclipse.birt.report.soapengine.endpoint.BirtSoapBindingImpl.getUpdatedObjects(BirtSoapBindingImpl.java:66)
at sun.reflect.GeneratedMethodAccessor34.invoke(Unknown Source)
at org.apache.axis.providers.java.RPCProvider.invokeMethod(RPCProvider.java:397)
at org.apache.axis.providers.java.RPCProvider.processMessage(RPCProvider.java:186)
at org.apache.axis.providers.java.JavaProvider.invoke(JavaProvider.java:323)
at org.apache.axis.strategies.InvocationStrategy.visit(InvocationStrategy.java:32)
at org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118)
at org.apache.axis.SimpleChain.invoke(SimpleChain.java:83)
at org.apache.axis.handlers.soap.SOAPService.invoke(SOAPService.java:454)
at org.apache.axis.server.AxisServer.invoke(AxisServer.java:281)
at org.apache.axis.transport.http.AxisServlet.doPost(AxisServlet.java:699)
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.doPost(BirtSoapMessageDispatcherServlet.java:265)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
at org.apache.axis.transport.http.AxisServletBase.service(AxisServletBase.java:327)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.service(BirtSoapMessageDispatcherServlet.java:122)
at org.eclipse.equinox.http.registry.internal.ServletManager$ServletWrapper.service(ServletManager.java:180)
at org.eclipse.equinox.http.servlet.internal.ServletRegistration.service(ServletRegistration.java:61)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.processAlias(ProxyServlet.java:126)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.service(ProxyServlet.java:60)
at org.eclipse.equinox.http.jetty.internal.HttpServerManager$InternalHttpServiceServlet.service(HttpServerManager.java:317)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:511)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:390)
at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:182)
at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:765)
at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
at org.mortbay.jetty.Server.handle(Server.java:326)
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:542)
at org.mortbay.jetty.HttpConnection$RequestHandler.content(HttpConnection.java:939)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:756)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:212)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:404)
at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:409)
at org.mortbay.thread.QueuedThreadPool$PoolThread.run(QueuedThreadPool.java:582)
Caused by: org.eclipse.birt.data.engine.core.DataException: A BIRT exception occurred. See next exception for more information.
commune
at org.eclipse.birt.data.engine.core.DataException.wrap(DataException.java:123)
at org.eclipse.birt.data.engine.script.ScriptEvalUtil.evaluateJSAsExpr(ScriptEvalUtil.java:996)
at org.eclipse.birt.data.engine.expression.ExprEvaluateUtil.doEvaluateRawExpression(ExprEvaluateUtil.java:281)
at org.eclipse.birt.data.engine.expression.ExprEvaluateUtil.evaluateRawExpression(ExprEvaluateUtil.java:236)
at org.eclipse.birt.data.engine.impl.PreparedDummyQuery$ResultIterator.<init>(PreparedDummyQuery.java:532)
at org.eclipse.birt.data.engine.impl.PreparedDummyQuery$ResultIterator.<init>(PreparedDummyQuery.java:509)
at org.eclipse.birt.data.engine.impl.PreparedDummyQuery$QueryResults.getResultIterator(PreparedDummyQuery.java:368)
at org.eclipse.birt.report.engine.data.dte.QueryResultSet.<init>(QueryResultSet.java:98)
at org.eclipse.birt.report.engine.data.dte.DteDataEngine.doExecuteQuery(DteDataEngine.java:168)
at org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.execute(AbstractDataEngine.java:267)
at org.eclipse.birt.report.engine.executor.ExecutionContext.executeQuery(ExecutionContext.java:1939)
at org.eclipse.birt.report.engine.executor.QueryItemExecutor.executeQuery(QueryItemExecutor.java:80)
... 58 more
Caused by: org.eclipse.birt.core.exception.CoreException: Error evaluating Javascript expression. Script engine error: ReferenceError: "commune" n'est pas défini
commune
at org.eclipse.birt.core.script.JavascriptEvalUtil.wrapRhinoException(JavascriptEvalUtil.java:303)
at org.eclipse.birt.core.script.JavascriptEvalUtil.evaluateRawScript(JavascriptEvalUtil.java:102)
at org.eclipse.birt.core.script.JavascriptEvalUtil.evaluateScript(JavascriptEvalUtil.java:134)
at org.eclipse.birt.data.engine.script.ScriptEvalUtil.evaluateJSAsExpr(ScriptEvalUtil.java:992)
... 68 more
Caused by: org.mozilla.javascript.EcmaError: ReferenceError: "commune" n'est pas défini
at org.mozilla.javascript.ScriptRuntime.constructError(ScriptRuntime.java:3654)
at org.mozilla.javascript.ScriptRuntime.constructError(ScriptRuntime.java:3632)
at org.mozilla.javascript.ScriptRuntime.notFoundError(ScriptRuntime.java:3717)
at org.mozilla.javascript.ScriptRuntime.nameOrFunction(ScriptRuntime.java:1758)
at org.mozilla.javascript.ScriptRuntime.name(ScriptRuntime.java:1697)
at org.mozilla.javascript.gen.c7._c0(unnamed script:0)
at org.mozilla.javascript.gen.c7.call(unnamed script)
at org.mozilla.javascript.ContextFactory.doTopCall(ContextFactory.java:398)
at org.mozilla.javascript.ScriptRuntime.doTopCall(ScriptRuntime.java:3065)
at org.mozilla.javascript.gen.c7.exec(unnamed script)
at org.eclipse.birt.core.script.JavascriptEvalUtil.evaluateRawScript(JavascriptEvalUtil.java:95)
... 70 more
with 'commune' as i defined is a Dataset full with a list of "code_commune".
how can i get out of this problem?
Please find two pictures one displaying the error and the other the my DataExplorer view in order to make it straightforward for you to understand the context in wich i'm working.
I really need your help
Attachment: parametre.JPG
(Size: 107.82KB, Downloaded 154 times) -
Attachment: erreur.JPG
(Size: 125.84KB, Downloaded 156 times)
Re: Error when generating the Birt report [message #897032 is a reply to message #896926] |
Fri, 20 July 2012 20:39 |
Are you setting the parameter values for the ? markers?
Jason
> select distinct
> UNION
> UNION
> UNION
> UNION
> UNION
> UNION
> UNION
> UNION
> UNION
> Quote:
>> Grid (id = 28):
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
>> commune
>> ... 58 more
>> commune
>> ... 68 more
>> ... 70 more
Current Time: Fri May 03 07:18:58 GMT 2024
Powered by FUDForum. Page generated in 0.02904 seconds
