Home » Modeling » GMF (Graphical Modeling Framework) » Problem while modifying resource.
Problem while modifying resource. [message #119413] Mon, 16 April 2007 04:51 Go to next message
I can't distinguish if the profile I have is GMF or EMF. But as I use
mostly GMF, I'm explaining it here.
In fact, I've created a View standing for a semantic element from
another resource (Shortcut). After that, while creating a relationship
(Edge) between two views (including the shortcut), I have to add
properties to the semantic element standing for the shortcut. And the
problem I have is that the element is not modified in the remote
resource (the properties never appear).
In Debug mode, the element to add to the remote semantic object is
correctly created, but I never see him appear in the model (semantic,
and graphical) ! I try to call Resource.save(), but this isn't working
too. This remote resource can be opened or closed. Nonetheless, If i'm
not using a shortcut, this works.
I think it is because my remote resource is not informed something has
changed. Where can I do that ?
Thanks a lot,
Maxence
Re: Problem while modifying resource. [message #119531 is a reply to message #119413] Mon, 16 April 2007 07:24 Go to previous messageGo to next message
Hello Maxence,
Are you using GMF 2.0 builds?
Alex Shatalin
Re: Problem while modifying resource. [message #119784 is a reply to message #119531] Mon, 16 April 2007 12:22 Go to previous messageGo to next message
Hello Alex,
We're actually using version 1.0 of GMF. What is the difference between
the two versions ?
Alex Shatalin a écrit :
> Hello Maxence,
> Alex Shatalin
Re: Problem while modifying resource. [message #119795 is a reply to message #119784] Mon, 16 April 2007 12:50 Go to previous message
Hello Maxence,
Generated ???DocumentProvider working with EMF resources was significantly
changed.
Alex Shatalin
Previous Topic:Can't drop a figure
Next Topic:Loading models in GMF
Current Time: Fri Jul 25 04:11:02 EDT 2025
Powered by FUDForum. Page generated in 0.09381 seconds
