Home » Modeling » ATL » How to improve my ATL transformation
How to improve my ATL transformation [message #882305] Wed, 06 June 2012 04:14
Is there a way to improve the performance of my ATL transformation, that to perform the injection in a Java XMI model does it in 223 seconds ?
This is the code:
rule createStatement {
	from
		imd : java!MethodDeclaration(
			--seleziono i metodi che hanno l'annotation
			imd.annotations -> exists(a | a.type.type.name='Annotation')
		to
		do{
--ciclo per ogni elemento di tipo SQLQuery che identifica una singola query
for (elemXMLSQL in xml!Element.allInstances()-> select(e | e.name = 'SQLQuery')) {
					--		importante operazione di controllo del valore dell'annotation con il nome della query
					if(imd.annotations.first().values.first().value.escapedValue.toString().endsWith(elemXMLSQL.getAttrVal('name').concat('"'))){
						if(elemXMLSQL.getAttrVal('type').endsWith('SIMPLE_SELECT')){
							imd.body.statements <- imd.body.statements -> append(thisModule.createHashMapParams(imd));
							for (elemXMLParams in elemXMLSQL.getChildren(Sequence{'params'})) {
								for (elemXMLParam in elemXMLParams.getChildren(Sequence{'param'})) {
									imd.body.statements <- imd.body.statements -> append(thisModule.createStatementParams(imd, elemXMLParam));
							--instanzio una nuova hashmap per gli into
							imd.body.statements <- imd.body.statements -> append(thisModule.createHashMapIntos(imd, elemXMLSQL));
							--generazione del blocco if
							imd.body.statements <- imd.body.statements -> append(thisModule.createIfStatementIntos(imd, elemXMLSQL));
							--mRT.performThrough(controlloSqlcode, exControlloSqlcode) ;
							imd.body.statements <- imd.body.statements -> append(thisModule.createStatementPerformThrough(imd));
thank you so much
[Updated on: Wed, 06 June 2012 04:43] by Moderator
Previous Topic:BPEL 2 XML using ATL
Next Topic:xmi:type instead of xsi:type
Current Time: Mon Jul 14 06:47:04 EDT 2025
Powered by FUDForum. Page generated in 0.07802 seconds
