Re: CDT editor performance problems [message #869963 is a reply to message #869898] |
Sat, 05 May 2012 09:12 |
Andreas Deinlein Messages: 6 Registered: July 2009 |
Junior Member |
Thanks for the hints. They are useful.
But I have the problems in the editor also while typing normal C/C++ elements or comments, not only on auto completion.
In my opinion, it has to do with live parsing/indexing ! When you type new syntax elements in the editor, you get immediately informed whether your syntax is right even before saving the file ! So the question is, how could i disable this functionality, so that the parser/indexer only works, when i save a file.
I already know the indexer preference page. There are two checkboxes:
- "Automatically update the index": "Activate this checkbox to have the index automatically update as it requires."
The question is what does this option really do ? What means "requires" ?
When i deactivate this, then also the second optiion is greyed out !
- "Update index immediately after every file-save": "Activate this checkbox to force an index update whenever a file is saved." This sounds like that, what I want to do, but even if it is checked, live check of syntax is still done. How could i deacivate this live parsing ?
Andreas
FUDForum. Page generated in 0.03517 seconds
