Home » Archived » BIRT » Problem with Birt Viewer 3.7.1 using Scripted data source
Problem with Birt Viewer 3.7.1 using Scripted data source [message #855153] Tue, 24 April 2012 11:10 Go to next message
I've created 2 separated projects: the first is a Java project that generates the report (rptdesign file) and the second is a dynamic web project based on JSF 2.0 which shows the report generated by the first project using jsp viewer taglib.
In the first project I used a scripted data source and here is my open script:
dataSetHandle.setOpen( "i = 0;\r\n"
				+"Pack1 = new Packages.calculMetrics.performanceMetrics.DataSet();\r\n"
				+"L = Pack1.getLabels();\r\n"
				+"V = Pack1.extractData(L);\r\n"
				+"Pack2 = new Packages.calculMetrics.performanceMetrics.OpenedW2D();\r\n"
				+"Pack2.openedw2d(V);\r\n"
				+"Pack3 = new Packages.calculMetrics.performanceMetrics.ClosedW10d();\r\n"
				+"Pack3.closedw10d(V);"
Where L is a list of Strings and V is a vector of classes
When I run my report in the Eclipse viewer I get no problems, same thing if I run it from a report Engine (using HTMLRenderOption()) I get the HTML report with no problem
but when I run it in Birt Viewer from the other project I get a strange error:
Script engine error: ReferenceError: "V" is not defined.
I attached below the stack trace.
Here is what I've done exactly in the web project:
- I created a dynamic web project v2.5
- I deployed Birt Viewer 3.7.1 in a GlassFish server v 3.1.2
- I copied the generated rptdesign file in the root directory of the viewer (D:\glassfish3\glassfish\domains\domain1\applications\birt)
- I copied some libs (SQL Server, Hibernate, ...) into the lib directory
- I copied the jar file of the first project in the scriptlib directory
- I tested the viewer using this jsp page:
<%@ page language="java" contentType="text/html; charset=ISO-8859-1"
pageEncoding="ISO-8859-1"%>
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN"
"http ://www.w3.org/TR/html4/loose.dtd">
<%@ taglib uri="http: //java.sun.com/jsf/core" prefix="f"%>
<%@ taglib uri="http: //java.sun.com/jsf/html" prefix="h"%>
<%@ taglib uri="/birt.tld" prefix="birt" %>
<html>
<f:view>
<body>
<birt:report id="birtViewer" reportDesign="PMetrics.rptdesign" baseURL="/birt"
height="600"
width="800"
format="html"
isHostPage="false"
reportContainer="iframe"
</birt:report>
</body>
</f:view>
</html>
I tested it with other sample reports and it worked perfectly
Environment:
- Eclipse BIRT 3.7.1 (all in one)
- BIRT runtime 3.7.1
- JDK 1.7
- GlassFish Server 3.1.2
- JSF 2.0
- Hibernate Tools 3.4.0
I can't understand why have I to define the vector V in the Javascript code of the second project however it works perfectly in the first one without definition.
Can anyone help me to solve this problem ???
Re: Problem with Birt Viewer 3.7.1 using Scripted data source [message #855206 is a reply to message #855153] Tue, 24 April 2012 11:51 Go to previous messageGo to next message
Claude,
My guess is that the calculMetrics.performanceMetrics package is not
being found. You could try
importPackage(Packages.calculMetrics.performanceMetrics);
Pack1 = new DataSet();
and add a simple file logger like:
importPackage( Packages.java.io );
out = new PrintWriter( new FileWriter( "c:/temp/scrptds.txt", true ) );
out.println( "Pack1 " + Pack1);
out.close();
to see if it is null.
Jason
On 4/24/2012 11:10 AM, Claude B wrote:
> <html>
> <f:view>
> <body>
> height="600"
> width="800"
> format="html"
> isHostPage="false"
> </birt:report>
> </body>
> </f:view>
> </html>
> Environment:
> - JDK 1.7
> - JSF 2.0
Re: Problem with Birt Viewer 3.7.1 using Scripted data source [message #855323 is a reply to message #855206] Tue, 24 April 2012 14:12 Go to previous messageGo to next message
Hi Jason,
Thank you for your quick response,
First I want to answer your question, I tried this code and the result was:
Pack1 calculMetrics.performanceMetrics.DataSet@1778087
but while doing this I realized that I ignored an important part of the log file, I'm so sorry I thought it was relative to an old execution, I attached the full log this time and I discovered that the problem is due to Hibernate, it can't find the hibernate.cfg.xml file so the extractData() method couldn't be executed and the vector is not created.
But I'm still confused because I've the hibernate.cfg.xml file in the root dir of my jar file and I can't understand why it can't find it. BTW I'm creating my jar file using Ant and here is the jar tag:
<target name="jar" depends="compile">
        <mkdir dir="${jar.dir}"/>
        <jar destfile="${jar.dir}/${ant.project.name}.jar" basedir="${classes.dir}">
            <manifest>
                <attribute name="Main-Class" value="${exec_report-class}"/>
            </manifest>
        	<fileset dir="src" />
        </jar>
    </target>
As you can see I added "<fileset dir="src" />" so that I can export my configuration and mapping xml files, the hibernate.cfg.xml file is in the src directory of the first project.
Any idea please!!!
Re: Problem with Birt Viewer 3.7.1 using Scripted data source [message #856365 is a reply to message #855323] Wed, 25 April 2012 11:41 Go to previous messageGo to next message
Claude,
As a test could you jar the hibernate config file by itself manually and
drop it in the web-inf/lib directory?
Jason
On 4/24/2012 2:12 PM, Claude B wrote:
> Hi Jason,
> Pack1 mailto:calculMetrics.performanceMetrics.DataSet@1778087
> <manifest>
> </manifest>
> </jar>
> </target>
> Any idea please!!!
Re: Problem with Birt Viewer 3.7.1 using Scripted data source [message #856462 is a reply to message #856365] Wed, 25 April 2012 13:30 Go to previous messageGo to next message
Hi Jason,
Thanks for your answers, they where helpful for me. Now I can run it perfectly.
In fact I had to delete the jar file containing the project from the scriptlib directory and I put it into the web-inf/lib directory, and this solved the problem Smile
Re: Problem with Birt Viewer 3.7.1 using Scripted data source [message #856470 is a reply to message #856462] Wed, 25 April 2012 13:42 Go to previous messageGo to next message
Jason, I have another question,
Now I'm going to integrate this web project into another web project which contains many other libs so I want to reduce the number of libs of the web viewer project. At first, I added all libs that I found in the web-inf/lib of the viewer to my project WebContent/web-inf/lib (84 libs) and now I want to delete unused libs: So can you tell me what are the necessary libs that I need to run the viewer???
Re: Problem with Birt Viewer 3.7.1 using Scripted data source [message #857586 is a reply to message #856470] Thu, 26 April 2012 13:22 Go to previous message
Claude this will really depend on what functions you want available to
the user. For example If you do not want to support flat file data
sources you could remove:
org.eclipse.datatools.connectivity.oda.flatfile_version.jar
Jason
Previous Topic:Concatenating logfiles as datasource based on report parameters
Next Topic:Report Error when generating
Current Time: Wed Jul 02 21:14:50 EDT 2025
Powered by FUDForum. Page generated in 0.05107 seconds
