Using Instrument collector for JMX & ARM Analysis [message #109763] |
Wed, 22 August 2007 05:23 |
Originally posted by: namratab.mastek.com
Hi all,
I am using TPTP 4.4.0 to profile application on Oracle standalone
application server(oc4j1013).
1. I start server in profiling mode by right clicking on the server
instance. In the prompted profile on server wizard,'m selecting the
instrument collector with my filter set. Also i have checked ARM analysis
by enabling generic probe and servlet probe.
After profiling , i can see three icons in the monitor view. But my
application is not running properly in this particular scenario. The
servlet mapping is not working and thus the execution statistics is not
available. Application works fine otherwise.I tried on tomcat 5.5
appserver, the application doesn't work there also.
Am i missing something?
2.Under instrument collector, the JMX analysis is selected with create
modelbeans for object and collect statistical information options. After
profiling, application runs.But when trying to open JMX analysis with
managed agent explorer, the error occurs saying problem in restoring the
options of the launch configuration.Reason displayed is
javax.naming.ServiceUnavailableException. This is probably because the
managed agent is not active and monitoring. How do i activate the managed
agent and use JMX analysis..?
Thanks in advance.
Re: Using Instrument collector for JMX & ARM Analysis [message #109865 is a reply to message #109810] |
Thu, 23 August 2007 11:05 |
Thanks for your kind help.
I have added VM arguments and the jar files you specified. But after i
say profile and sirf my application, in profile monitor no view is
available.. Server shows profiling as its status.
Some more guidance will be of great help.
~Namrata
FUDForum. Page generated in 0.05765 seconds
