| TPTP of webapps? [message #109423] |
Fri, 17 August 2007 11:31 |
Originally posted by: solson.ameren.com
I'm struggling with getting a local invocation of Tomcat for heap profiling
to run. The config is JRE 1.6_01, Tomcat 6.0.13, Eclipse 3.3, TPTP 4.4.0.1
on winXP. Is there a correct supported way to do this, or is bug 199632
relevant? I ask about that bug even though it is Linux-related, as the
various attempts I have made have always resulted in Tomcat failing at
startup with a JPIBootLoader failure similar to the one mentioned in that
bug.
If this should work, can someone point me at a how to or other info that
describes the specifics required to get a local tomcat, invoked by eclipse,
under profiling?
FUDForum. Page generated in 0.09370 seconds
