Home » Archived » COSMOS » javax.persistance - where from?
javax.persistance - where from? [message #9457] Fri, 02 November 2007 09:29 Go to next message
After checking out project "org.eclipse.cosmos.dc.sample.jpa" I get tons
of errors due to misc. "import javax.persistance.<xyz>" classes that
can't be resolved. Where is this javax.persistance stuff supposed to
come from?
Michael
Re: javax.persistance - where from? [message #9481 is a reply to message #9457] Mon, 05 November 2007 10:45 Go to previous messageGo to next message
> come from?
> Michael
I get the same errors when I load that project. I'm told that the
project is obsolete. I am checking with the person who contributed that
project to see if it can be removed from the repository to avoid confusion.
David
Re: javax.persistance - where from? [message #9503 is a reply to message #9481] Wed, 14 November 2007 13:33 Go to previous messageGo to next message
>> tons of errors due to misc. "import javax.persistance.<xyz>" classes
>> that can't be resolved. Where is this javax.persistance stuff supposed
>> to come from?
>> Michael
> David
I have confirmed that we no longer use javax.persistence in COSMOS. The
defect https://bugs.eclipse.org/bugs/show_bug.cgi?id=209839 has been
opened to remove this sample from CVS.
David
Re: javax.persistance - where from? [message #9592 is a reply to message #9503] Tue, 27 November 2007 12:21 Go to previous message
OK - I'll simply delete that project then. Thanks for your
"investigation efforts" in clarifying this.
Michael
>>> supposed to come from?
>>> Michael
>> that project to see if it can be removed from the repository to
>> avoid confusion. David
> The defect https://bugs.eclipse.org/bugs/show_bug.cgi?id=209839 has
> been opened to remove this sample from CVS.
> David
Re: javax.persistance - where from? [message #570561 is a reply to message #9457] Mon, 05 November 2007 10:45 Go to previous message
> come from?
> Michael
David
Re: javax.persistance - where from? [message #570600 is a reply to message #9481] Wed, 14 November 2007 13:33 Go to previous message
>> to come from?
>> Michael
> David
David
Re: javax.persistance - where from? [message #570711 is a reply to message #9503] Tue, 27 November 2007 12:21 Go to previous message
Michael
>>> Michael
> David
Previous Topic:COSMOS for high-performance computing
Next Topic:How and what to check out from CVS?
Current Time: Mon Oct 06 15:39:05 EDT 2025
Powered by FUDForum. Page generated in 0.04657 seconds
