Re: Creating Features and Plugins in a RCP-App [message #845856 is a reply to message #827398] |
Sun, 15 April 2012 13:34 |
Wim Jongman Messages: 423 Registered: July 2009 |
Hi Sebastian,
You are on you own. However, I would like to see this code on github
sometime. ;)
Wim
> Hallo,
> I am creating an Authoring Tool based on RCP. The Authoring Tool has two
Extension-Points. One Extension Point is for SimpleComponents and one for
AggregateComponents. SimpleComponents are Features created with the Eclipse
IDE. Via p2 I can export the SimpleComponents and use them in my RCP-App.
That works fine.
> Now I use the Authoring Tool to combine the SimpleComponents to
AggregateComponents. In the background, these AggregateComponents should be
realised as Plugins, combined to Features with the used SimpleComponents. So
I am looking for a way to create Plugins and Features programmatically or via
Ant-Tasks. And I want to export the created Features programmatically or via
Ant-Tasks, so that the AggregateComponents can be used by other instances of
the AuthoringTool.
> I tried to integrate the pde-functionalities of the Eclipse-IDE in my
RCP-App, but it became to big. AggregateComponents do not contain any source
code. They only contain serialized EMF-EObjects, so I have no need for
build-functionalities. In fact I only need the MANIFEST.MF and the
feature.xml to be created. Do I have to do this on my own or are there
prepared solutions for that use case.
> best regards, Sebastian
FUDForum. Page generated in 0.03719 seconds
