log4j warning message after reading FAQ [message #822533] |
Fri, 16 March 2012 20:51 |
mike fulton Messages: 3 Registered: December 2011 |
After following the suggestions in the FAQ, I am still getting a warning regarding log4j.xml:
log4j:WARN No appenders could be found for logger (org.eclipse.swtbot.swt.finder.matchers.AbstractMatcher).
log4j:WARN Please initialize the log4j system properly.
Note the particular class it is complaining about is different than the one in the FAQ - not sure if that matters...
I have put the log4j.xml in my 'src' directory and I have updated my MANIFEST.MF to now include the changes recommended from the FAQ:
Require-Bundle: org.eclipse.swtbot.swt.finder;bundle-version="2.0.5",
org.eclipse.swtbot.eclipse.finder;bundle-version="2.0.5",
org.hamcrest;bundle-version="1.1.0",
org.apache.log4j;bundle-version="1.2.15",
org.junit4;bundle-version="4.8.1",
org.eclipse.ui.browser;bundle-version="3.3.100",
org.eclipse.swtbot.eclipse.ui;bundle-version="2.0.5",
org.eclipse.swtbot.eclipse.core;bundle-version="2.0.5",
org.eclipse.swtbot.go,
org.apache.log4j
Eclipse-RegisterBuddy: org.apache.log4j
Thank you, in advance, for your help
Mike
Re: log4j warning message after reading FAQ [message #1202644 is a reply to message #822533] |
Fri, 22 November 2013 08:43 |
pascale prost Messages: 2 Registered: November 2013 |
Hello Mike,
Did you solve your problem ? I have the same issue and I would be interrested in the solution if you found it ...
I have of course newer versions of all packages, this is my MANIFEST.MF :
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: First
Bundle-SymbolicName: com.prostp.swtbotTestPlugin.first;singleton:=true
Bundle-Version: 1.0.0.qualifier
Bundle-ActivationPolicy: lazy
Bundle-Vendor:
PROSTP
Bundle-RequiredExecutionEnvironment: J2SE-1.5
Require-Bundle: org.eclipse.ui;bundle-version="3.105.0",
org.eclipse.core.runtime;bundle-version="3.9.0",
org.eclipse.debug.core;bundle-version="3.8.0",
org.eclipse.swtbot.eclipse.finder;bundle-version="2.1.1",
org.eclipse.swtbot.junit4_x;bundle-version="2.1.1",
org.junit;bundle-version="4.11.0",
org.hamcrest.library;bundle-version="1.3.0",
org.eclipse.swtbot.go;bundle-version="2.1.1"
Thanks ahead,
Pascale
FUDForum. Page generated in 0.03019 seconds
