colapse and expand values on +,- click(tree table) on cross tabs [message #815459] |
Wed, 07 March 2012 17:40 |
marina tzerluk Messages: 13 Registered: February 2012 |
i have this report attached bellow with screen shot.
need to add some colapsing and expanding functionality in cross tab.
I need to add some hiding to the location values. I want to add "+" near the application column which on click will expand and show all locations(Hollywood, jamaika...) after expansion the sign will turn to "-" and it will hide all the locations on click. I want that only the first row with the missing location will be visible always in expanded locations view and collapsed.
please suggest how can i do so?
[Updated on: Wed, 07 March 2012 18:04] Report message to a moderator
Re: colapse and expand values on +,- click(tree table) on cross tabs [message #869670 is a reply to message #868584] |
Thu, 03 May 2012 15:19 |
I do not have an expand/collapse crosstab example, but I do have an
example of using the api to create a crosstab which is attached. Also
if you want to do it in script look at this example:
http://www.birt-exchange.org/org/devshare/designing-birt-reports/1181-dynamic-xtab-creation-using-script/
That example uses parameters to determine what to display.
Jason
On 5/2/2012 5:02 AM, Nandish A wrote:
> Hello Birt Experts,
> Please help us in resolving this issue. I see a older conversation http
> www dot
> eclipse.org/forums/index.php/m/259413/dae72fa26c73a56d1354648a0f426c39/?srch=cross+tab+dynamic#msg_259413
> which is yet to be cleared. Do we have a example for dynamic cross tabs
FUDForum. Page generated in 0.03408 seconds
