Re: New+CTRL+SPACE in Scrapbook [message #813515 is a reply to message #813501] |
Mon, 05 March 2012 11:13 |
Scrapbook is not intented as full-fledged Java editor. Most probably there is just no enough clever auto-complete.
I recommend do not waste your time with this issue but use Java editor instead (which provide auto-complete for this).
Good luck with learning Java!
Re: New+CTRL+SPACE in Scrapbook [message #869492 is a reply to message #813501] |
Thu, 03 May 2012 13:25 |
Dani Megert Messages: 3802 Registered: July 2009 |
On 05.03.2012 11:47, Richard Scutter wrote:
> Hi, I originally posted this in the Newcomers forum, I've had a lot of
> hits but no response.
> Then it occurred to me that there has recently been a new release
> (Indigo) which I am using, and is a different version to the Eclipse
> being used in the Tutorial.
> In case this is a new problem which has crept into the product (or,
> more likely I've missed some setting in the new product), I'm posting
> this here in case someone knows the answer ...
> While following the 16 part tutorial "Eclipse and Java for Total
> Beginners" (Which is Very Good) we got to the part about ArrayList, I
> typed the following in the Scrapbook:
> New (followed by CTRL+SPACE) which did nothing.
Content Assist expects at least 1 character. Try "new A" + Ctrl+Space
Dani
> When I use this inside a Class it works fine, and should allow me to
> select the Template for New Object.
> Do I need to change an Options setting? Or is this a problem?
> Richard.
FUDForum. Page generated in 0.03134 seconds
