servlet linkage error when using servlet bridge [message #93233] |
Mon, 30 July 2007 04:54 |
Originally posted by: dkrebs.tibco.com
This one is totally killing me. I'm trying to run the servlet bridge
framework in tomcat6 and have traced down the issue to this part of the
log file, I get the general idea that its complaining about different
class versions of the servlet class but don't know how to fix the problem,
any ideas would be appreciated. - Duncan
used by: java.lang.LinkageError: loader constraint violation: when
resolving method
" org.eclipse.equinox.servletbridge.BridgeServlet.registerServ letDelegate(Ljavax/servlet/http/HttpServlet;)V "
the class loader (instance of
org/eclipse/osgi/internal/baseadaptor/DefaultClassLoader) of the current
class, org/eclipse/equinox/http/servletbridge/internal/Activator, and the
class loader (instance of org/apache/catalina/loader/WebappClassLoader)
for resolved class, org/eclipse/equinox/servletbridge/BridgeServlet, have
different Class objects for the type javax/servlet/http/HttpServlet used
in the signature
org.eclipse.equinox.http.servletbridge.internal.Activator.st art(Activator.java:28)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:999)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:993)
... 8 moreused by: java.lang.LinkageError: loader constraint violation:
when resolving method
in the signature
... 8 more
Re: servlet linkage error when using servlet bridge [message #93266 is a reply to message #93233] |
Mon, 30 July 2007 13:10 |
Simon Kaegi Messages: 381 Registered: July 2009 |
Do you have the javax.servlet (or org.eclipse.equinox.servlet.api) bundle in
your install?
You shouldn't have this with the servletbridge. The javax.servlet packages
are exposed with a framework extension bundle called
org.eclipse.equinox.servlletbridge.extensionbundle.
HTH
-Simon
"Duncan Krebs" <dkrebs@tibco.com> wrote in message
news:6bdf9602fa7fed6c679c38225a3237ae$1@www.eclipse.org...
> Hi, This one is totally killing me. I'm trying to run the servlet bridge
> resolving method
> in the signature
> at
> at
> at java.security.AccessController.doPrivileged(Native Method)
> at
> in the signature
> at
> at
> at
> ... 8 more
Re: servlet linkage error when using servlet bridge [message #93297 is a reply to message #93266] |
Mon, 30 July 2007 14:27 |
Simon,
Thanks for the post, I had a lib bundle that contained the API and was
able to get it figured out. On a high level I think running OSGI in a
servlet container is great, especially because I've been able to wrap the
web.xml as extension points and also break my UI into extension points. I
just get nervous when things don't work in the servlet container because I
don't know of a way to debug an OSGI app while in tomcat for example,
hopefully this will take care of it though, if not some tutorials on class
loading might help. - Duncan
> your install?
> HTH
> -Simon
FUDForum. Page generated in 0.03973 seconds
