Home » Modeling » OCL » OCLInEcore recursive operations
OCLInEcore recursive operations [message #786086] |
Sun, 29 January 2012 19:55  |
Hello
I'm trying to make an recursive operation with OCLInEcore, but it's thrown an error that the operation was not found. Is there any solution to this problem? Does OCLInEcore does not support recursive functions? I'm doing something like this:
operation rec(n: Type1): Type2
body: if self = n then 0
else n.childs->iterate(e: Type3; acc:Integer=0 | if e.rev() > acc then e.DIT() else acc endif) endif;
Re: OCLInEcore recursive operations [message #786566 is a reply to message #786296] |
Mon, 30 January 2012 10:34   |
I'm using Eclipse Modeling Tools Version: Indigo Service Release 1 Build id: 20110916-0149.
That was a simple example I came with at the moment. My problem is in a larger scale. Anyway where it is, maybe you can see any error that I'm not seeing right.
package KAOSStandard : kaos = 'kaos'
class KAOS
property hasCompartmentNode : CompartmentNode[*] { ordered composes };
property hasNodes : Nodes[*] { ordered composes };
property hasLinks : Links[*] { ordered composes };
property root : Goal[1] { ordered };
operation modelDepth() : ecore::EIntegerObject[1]
body:
self.goalsDistanceToRoot(self.root, Set{0}, 0)->iterate(i : Integer ; m : Integer = - 1 | if m = - 1 then i else m.max(i) endif);
operation goalsDistanceToRoot(n : Nodes[1], dist : ecore::EIntegerObject[*], last : ecore::EIntegerObject[1]) :
body:
if n.oclIsKindOf(Goal) then
self.depthOfGoal(n.oclAsType(Goal), dist, last)
else
if n.oclIsKindOf(Obstacle) then
self.depthOfObstacle(n.oclAsType(Obstacle), dist, last)
else
dist
endif
endif;
operation depthOfGoal(g : Goal[1], dist : ecore::EIntegerObject[*], last : ecore::EIntegerObject[1]) :
body:
if g.isLeafGoal() then
self.depthOfLeafGoal(g, dist, last)
else
self.union(g.goalIsAndRef->collect(andRefToOtherGoal)->union(g.goalIsOrRef->collect(orRefToOtherGoal))->asSet(), g.goalHasObstacle->collect(obstacle)->asSet())->collect(n : Nodes | self.goalsDistanceToRoot(n, dist->including(last + 1), last + 1))->asSet()
endif;
operation union(s1 : Goal[*], s2 : Nodes[*]) : Nodes[*]
body: let s : Set(Nodes) = Set{} in s->union(s1)->union(s2);
operation depthOfLeafGoal(g : Goal[1], dist : ecore::EIntegerObject[*], last : ecore::EIntegerObject[1]) :
body:
let s : Sequence(Obstacle) = g.goalHasObstacle->collect(obstacle) in
if s->notEmpty() then
s->collect(o : Obstacle | self.goalsDistanceToRoot(o.oclAsType(Nodes), dist->including(last + 1), last + 1))->asSet()
else
dist
endif;
operation depthOfObstacle(o : Obstacle[1], dist : ecore::EIntegerObject[*], last : ecore::EIntegerObject[1]) :
body:
if self.isLeafObstacle(o) then
self.depthOfLeafObstacle(o, dist, last)
else
self.obstacleRefinement(o)->collect(o : Obstacle | self.goalsDistanceToRoot(o.oclAsType(Nodes), dist->including(last + 1), last + 1))->asSet()
endif;
operation obstacleRefinement(o : Obstacle[1]) : Obstacle[*]
body:
self.hasLinks->select(l : Links | l.oclIsKindOf(ObstacleRefinement) and l.oclAsType(ObstacleRefinement).obstToObstRef = o)->collect(oclAsType(ObstacleRefinement))->collect(obstRefToObst);
operation depthOfLeafObstacle(o : Obstacle[1], dist : ecore::EIntegerObject[*], last : ecore::EIntegerObject[1]) :
body:
let s : Sequence(Goal) = o.solution->collect(obstacleHasSolution) in
s->collect(g : Goal | self.goalsDistanceToRoot(g.oclAsType(Nodes), dist->including(last + 1), last + 1))->asSet()
else
dist
endif;
operation isLeafObstacle(o : Obstacle[1]) : Boolean[1]
body:
not self.hasLinks->exists(l : Links | (l.oclIsKindOf(ObstacleRefinement) and l.oclAsType(ObstacleRefinement).obstToObstRef = o));
annotation _'gmf.diagram'
foo = 'bar'
abstract class Nodes
attribute name : String[?] { ordered };
attribute TransformationSource : String[?] { ordered };
attribute IstarActorContainer : String[?] { ordered };
annotation _'gmf.node'
label = 'name',
_'label.placement' = 'external'
class Goal extends Nodes
attribute formalDef : String[?] { ordered };
attribute informalDef : String[?] { ordered };
property goalIsOrRef#orRefToGoal : OrRefinement[*] { ordered };
property otherGoalIsOrRef#orRefToOtherGoal : OrRefinement[*] { ordered };
property goalIsAndRef#andRefToGoal : AndRefinement[*] { ordered };
property otherGoalIsAndRef#andRefToOtherGoal : AndRefinement[*] { ordered };
property goalHasObstacle#obstacleToGoal : ObstructionLink[*] { ordered };
property solutionIsGoal#obstacleHasSolution : SolutionLink[*] { ordered };
property goalToOperatLink#operatLinkToGoal : OperationalizationLink[*] { ordered };
property goalConcerns#concernedByGoal : ConcernsLink[*] { ordered };
property goalHasDomProp#DomPropLinkToGoal : DomainPropLink[*] { ordered };
operation isLeafGoal() : Boolean[1]
body: self.goalIsAndRef->isEmpty() and self.goalIsOrRef->isEmpty();
color = '0,191,255',
_'border.color' = '0,191,255',
size = '80,50',
figure = 'polygon',
_'polygon.x' = '30 70 50 10',
_'polygon.y' = '10 10 40 40',
_'tool.description' = 'Create new Goal'
class Obstacle extends Nodes
property obstacleObstruction#obstacle : ObstructionLink[*] { ordered };
property solution#obstacleSolution : SolutionLink[*] { ordered };
color = '255,140,0',
_'border.color' = '255,140,0',
size = '80,50',
figure = 'polygon',
_'polygon.x' = '10 50 70 30',
_'tool.description' = 'Create new Obstacle'
abstract class Links
attribute Source : String[?] { ordered };
attribute Target : String[?] { ordered };
class OrRefinement extends Links
invariant linkToHimself('Goal ' + orRefToGoal.name + ' can not be a refinement of himself.'):
orRefToGoal <> orRefToOtherGoal;
property orRefToGoal#goalIsOrRef : Goal[1] { ordered };
property orRefToOtherGoal#otherGoalIsOrRef : Goal[1] { ordered };
annotation _'gmf.link'
source = 'orRefToGoal',
target = 'orRefToOtherGoal',
color = '0,0,255',
_'target.decoration' = 'arrow',
width = '2',
style = 'dash',
_'tool.description' = 'Create new OrRefinement between Goal, Requirement or Expectation'
class AndRefinement extends Links
invariant linkToHimself('Goal ' + andRefToGoal.name + ' can not be a refinement of himself.'):
andRefToGoal <> andRefToOtherGoal;
property andRefToGoal#goalIsAndRef : Goal[1] { ordered };
property andRefToOtherGoal#otherGoalIsAndRef : Goal[1] { ordered };
source = 'andRefToGoal',
target = 'andRefToOtherGoal',
color = '0,0,255',
width = '2',
_'tool.description' = 'Create new AndRefinement between Goal, Requirement or Expectation'
class ObstacleRefinement extends Links
invariant linkToHimself('Obstacle ' + obstRefToObst.name + ' can not be a refinement of himself.'):
obstRefToObst <> obstToObstRef;
property obstRefToObst : Obstacle[1] { ordered };
property obstToObstRef : Obstacle[1] { ordered };
source = 'obstRefToObst',
target = 'obstToObstRef',
width = '2',
_'tool.description' = 'Create new ObstacleRefinement between Obstacles'
class ObstructionLink extends Links
property obstacle#obstacleObstruction : Obstacle[1] { ordered };
property obstacleToGoal#goalHasObstacle : Goal[1] { ordered };
source = 'obstacle',
target = 'obstacleToGoal',
color = '255,165,0',
width = '2',
_'tool.description' = 'Create new ObstructionLink between an Obstacle and a Goal, Requirement or Expectation'
class SolutionLink extends Links
property obstacleHasSolution#solutionIsGoal : Goal[1] { ordered };
property obstacleSolution#solution : Obstacle[1] { ordered };
source = 'obstacleHasSolution',
target = 'obstacleSolution',
color = '0,139,0',
width = '2',
_'tool.description' = 'Create new SolutionLink between an Obstacle and a Goal, Requirement or Expectation'
Re: OCLInEcore recursive operations [message #786632 is a reply to message #786566] |
Mon, 30 January 2012 12:00   |
Your example has many "..." ellisions and no CompartmentNode, so I
cannot comment on what real problems exist.
Ed Willink
> class KAOS
> composes };
> body:
> m.max(i) endif);
> body:
> self.depthOfGoal(n.oclAsType(Goal), dist, last) else
> dist, last) else dist
> endif endif;
> body:
> self.depthOfLeafGoal(g, dist, last) else
> 1))->asSet() endif;
> body:
> g.goalHasObstacle->collect(obstacle) in if
> s->notEmpty() then s->collect(o : Obstacle |
> 1), last + 1))->asSet() else
> dist endif;
> body:
> self.depthOfLeafObstacle(o, dist, last) else
> 1), last + 1))->asSet() endif;
> body:
> body:
> o.solution->collect(obstacleHasSolution) in if
> s->notEmpty() then s->collect(g : Goal |
> dist endif;
> body:
> foo = 'bar'
> label = 'name',
> ordered };
> ordered };
> ordered };
> { ordered };
> ordered };
> { ordered };
> size = '80,50',
> figure = 'polygon',
> ordered };
> size = '80,50',
> figure = 'polygon',
> color = '0,0,255',
> width = '2',
> style = 'dash',
> ordered };
> color = '0,0,255',
> width = '2',
> width = '2',
> between Obstacles'
> width = '2',
> ordered };
> color = '0,139,0',
> width = '2',
Re: OCLInEcore recursive operations [message #786659 is a reply to message #786632] |
Mon, 30 January 2012 12:28  |
I though what it was more simple if a do not put the entire example. Anyway here it is:
module _'KAOS.ecore'
import ecore : 'http://www.eclipse.org/emf/2002/Ecore#/';
class KAOS
operation numLeafGoals() : ecore::EIntegerObject[?]
body: self.hasNodes->select(n : Nodes | n.oclIsKindOf(Goal) and n.oclAsType(Goal).isLeafGoal())->size();
operation numLeafGoalsWithAgents() : ecore::EIntegerObject[?]
body:
self.hasNodes->select(n : Nodes | n.oclIsKindOf(Goal) and n.oclAsType(Goal).isLeafGoal() and n.oclAsType(Goal).goalNumberOfAgents() > 0)->size();
operation numLeafGoalsWithObjects() : ecore::EIntegerObject[?]
body:
self.hasNodes->select(n : Nodes | n.oclIsKindOf(Goal) and n.oclAsType(Goal).isLeafGoal() and n.oclAsType(Goal).goalNumberOfObjects() > 0)->size();
operation numLeafObstacles() : ecore::EIntegerObject[?]
body:
self.hasNodes->select(n : Nodes | n.oclIsKindOf(Obstacle) and not self.hasLinks->exists(l : Links | (l.oclIsKindOf(ObstacleRefinement) and l.oclAsType(ObstacleRefinement).obstToObstRef = n.oclAsType(Obstacle))))->size();
operation numLeafGoalsWithOperations() : ecore::EIntegerObject[?]
body:
self.hasNodes->select(n : Nodes | n.oclIsKindOf(Goal) and n.oclAsType(Goal).isLeafGoal() and n.oclAsType(Goal).goalNumberOfOperations() > 0)->size();
operation numOperations() : ecore::EIntegerObject[?]
body: self.hasNodes->select(n : Nodes | n.oclIsKindOf(OperationNode))->size();
operation numOperationsWithAgents() : ecore::EIntegerObject[?]
body:
self.hasNodes->select(n : Nodes | n.oclIsKindOf(OperationNode) and n.oclAsType(OperationNode).operationNumberOfAgents() > 0)->size();
operation numAgents() : ecore::EIntegerObject[?]
body: self.hasNodes->select(n : Nodes | n.oclIsKindOf(Agent))->size();
operation numLeafGoalsWithConcerns() : ecore::EIntegerObject[?]
body:
self.hasLinks->select(l : Links | l.oclIsKindOf(ConcernsLink) and l.oclAsType(ConcernsLink).concernedByGoal.isLeafGoal())->size();
body:
body:
if n.oclIsKindOf(Goal) then self.depthOfGoal(n.oclAsType(Goal), dist, last) else if n.oclIsKindOf(Obstacle) then self.depthOfObstacle(n.oclAsType(Obstacle), dist, last) else dist endif endif;
body:
if g.isLeafGoal() then self.depthOfLeafGoal(g, dist, last) else self.union(g.goalIsAndRef->collect(andRefToOtherGoal)->union(g.goalIsOrRef->collect(orRefToOtherGoal))->asSet(), g.goalHasObstacle->collect(obstacle)->asSet())->collect(n : Nodes | self.goalsDistanceToRoot(n, dist->including(last + 1), last + 1))->asSet() endif;
body:
let s : Sequence(Obstacle) = g.goalHasObstacle->collect(obstacle) in if s->notEmpty() then s->collect(o : Obstacle | self.goalsDistanceToRoot(o.oclAsType(Nodes), dist->including(last + 1), last + 1))->asSet() else dist endif;
body:
if self.isLeafObstacle(o) then self.depthOfLeafObstacle(o, dist, last) else self.obstacleRefinement(o)->collect(o : Obstacle | self.goalsDistanceToRoot(o.oclAsType(Nodes), dist->including(last + 1), last + 1))->asSet() endif;
body:
body:
let s : Sequence(Goal) = o.solution->collect(obstacleHasSolution) in if s->notEmpty() then s->collect(g : Goal | self.goalsDistanceToRoot(g.oclAsType(Nodes), dist->including(last + 1), last + 1))->asSet() else dist endif;
body:
operation depth() : ecore::EIntegerObject[1]
body:
let s : OrderedSet(Nodes) = OrderedSet{self.root.oclAsType(Goal)} in s->iterate(n : Nodes ; i : Integer = 0 | s = s->union(n.oclAsType(Goal).goalIsAndRef->collect(andRefToOtherGoal)->asOrderedSet())->excluding(n) and i = i + 1);
operation modelDit() : ecore::EIntegerObject[1]
body:
self.hasNodes->iterate(n : Nodes ; i : Integer = 0 | if n.oclIsKindOf(Goal) and n.oclAsType(Goal).dit(self.root) > i then n.oclAsType(Goal).dit(self.root) else i endif);
foo = 'bar'
abstract class CompartmentNode
class GoalCompartmentNode extends CompartmentNode
property compHasGoals : Goal[*] { ordered composes }
annotation _'gmf.compartment'
layout = 'free'
label = 'name',
_'border.color' = '0,0,255',
size = '200,100',
_'border.width' = '2',
'Create new GoalCompartmentNode for inserting Goals, Requirements and Expectations in the diagram'
class SoftgoalCompartmentNode extends CompartmentNode
property softgoalCompHasSoftgoals : Softgoal[*] { ordered composes }
layout = 'free'
label = 'name',
_'border.color' = '0,100,0',
size = '200,100',
_'tool.description' = 'Create new SoftgoalCompartmentNode for inserting Softgoals in the diagram'
class ObstacleCompartmentNode extends CompartmentNode
property obstCompNodeHasObstacle : Obstacle[*] { ordered composes }
layout = 'free'
label = 'name',
_'border.color' = '255,165,0',
size = '200,100',
_'tool.description' = 'Create new ObstacleCompartmentNode for inserting Obstacles in the diagram'
class DomainPropertiesCompartmentNode extends CompartmentNode
property domProCompNodeHasDomProp : DomainProperties[*] { ordered composes }
layout = 'free'
label = 'name',
_'border.color' = '148,0,211',
size = '200,100',
'Create new DomainPropertiesCompartmentNode for inserting Domain Invariants and Domain Hipothesis in the diagram'
class AgentCompartmentNode extends CompartmentNode
property agentCompHasAgent : Agent[*] { ordered composes }
layout = 'free'
label = 'name',
_'border.color' = '255,105,180',
size = '200,100',
'Create new AgentCompartmentNode for inserting System Agents and Environment Agents in the diagram'
class ObjectCompartmentNode extends CompartmentNode
property objCompHasObjects : Object[*] { ordered }
layout = 'free'
label = 'name',
_'border.color' = '165,42,42',
size = '200,100',
_'tool.description' = 'Create new ObjectCompartmentNode for creating Entities and Events in the diagram'
class OperationCompartmentNode extends CompartmentNode
property hasOperationNodes : OperationNode[*] { ordered }
layout = 'free'
label = 'name',
size = '200,100',
_'tool.description' = 'Create new OperationCompartmentNode for inserting Operations in the diagram'
label = 'name',
operation goalAgents() : Agent[*]
body:
let s : Sequence(Agent) = if self.oclIsKindOf(Expectation) then self.oclAsType(Expectation).expToAgentExpLink->collect(expLinkToAgent) else if self.oclIsKindOf(Requirement) then self.oclAsType(Requirement).ReqToAgentReqLink->collect(ReqToAgentLink) else Sequence{} endif endif in s->union(self.otherGoalIsOrRef->collect(orRefToGoal)->union(self.otherGoalIsAndRef->collect(andRefToGoal))->collect(g : Goal | g.goalAgents()));
operation goalNumberOfAgents() : ecore::EIntegerObject[?]
body: self.goalAgents()->size();
operation goalNumberOfObjects() : ecore::EIntegerObject[?]
body: self.goalConcerns->collect(concernsObject)->size();
operation goalNumberOfOperations() : ecore::EIntegerObject[?]
body: self.goalToOperatLink->collect(operatLinkToOperationNode)->size();
size = '80,50',
figure = 'polygon',
class Requirement extends Goal
property ReqToAgentReqLink#agentReqLinkToReq : AgentReqLink[+] { ordered };
_'border.color' = '0,0,0',
size = '80,50',
figure = 'polygon',
_'tool.description' = 'Create new Requirement'
class Expectation extends Goal
property expToAgentExpLink#agentExpLinkToExp : AgentExpLink[+] { ordered };
color = '255,215,0',
_'border.color' = '255,215,0',
size = '80,50',
figure = 'polygon',
_'tool.description' = 'Create new Expectation'
class Softgoal extends Goal
color = '50,205,50',
_'border.color' = '50,205,50',
size = '40,40',
figure = 'ellipse',
_'tool.description' = 'Create new Softgoal'
operation obstacleNumberOfSolutions() : ecore::EIntegerObject[?]
body: self.solution->size();
size = '80,50',
figure = 'polygon',
abstract class DomainProperties extends Nodes
property domPropToGoal#goalToDomProp : DomainPropLink[+] { ordered };
class DomainInvariant extends DomainProperties
color = '221,160,221',
_'border.color' = '221,160,221',
size = '80,50',
figure = 'polygon',
_'polygon.x' = '10 40 70 70 10',
_'polygon.y' = '20 10 20 40 40',
_'tool.description' = 'Create new DomainInvariant'
class DomainHyphothesis extends DomainProperties
color = '147,112,219',
_'border.color' = '147,112,219',
size = '80,50',
figure = 'polygon',
_'tool.description' = 'Create new DomainHyphothesis'
abstract class Object extends Nodes
property objToInhLink#inhLinkToObject : InheritanceLink[*] { ordered };
property otherObjToInhLink#inhLinkToOtherObj : InheritanceLink[*] { ordered };
property objToAggLink#aggLinkToObject : AggregationLink[*] { ordered };
property otherObjToAggLink#aggLinkToOtherObject : AggregationLink[*] { ordered };
property objToCardLink#cardLinkToObject : CardinalityLink[*] { ordered };
property otherObjToCardLink#cardLinkToOtherObject : CardinalityLink[*] { ordered };
property objIsMonitored#monLinkToObject : MonitorsLink[*] { ordered };
property objIsControlled#contLinkToObject : ControlsLink[*] { ordered };
property objectIsConcerned#concernsObject : ConcernsLink[*] { ordered };
abstract class Agent extends Object
property agentMonitors#monLinkToAgent : MonitorsLink[*] { ordered };
property agentControls#contLinkToAgent : ControlsLink[*] { ordered };
property agentPerforms#perLinkToAgent : PerformsLink[*] { ordered };
operation agentNumberOfLeafGoals() : ecore::EIntegerObject[?]
body:
if self.oclIsKindOf(EnvironmentAgent) then self.oclAsType(EnvironmentAgent).numLeafGoals() else if self.oclIsKindOf(SystemAgent) then self.oclAsType(SystemAgent).numLeafGoals() else 0 endif endif;
class SystemAgent extends Agent
property agentToReqLink#ReqToAgentLink : AgentReqLink[+] { ordered };
body: self.agentToReqLink->collect(agentReqLinkToReq)->size();
color = '255,160,122',
_'border.color' = '255,160,122',
size = '80,50',
figure = 'polygon',
_'polygon.x' = '10 20 60 70 60 20',
_'polygon.y' = '25 40 40 25 10 10',
_'tool.description' = 'Create new SystemAgent'
class EnvironmentAgent extends Agent
property agentToExpLink#expLinkToAgent : AgentExpLink[+] { ordered };
body: self.agentToExpLink->collect(agentExpLinkToExp)->size();
color = '255,182,193',
_'border.color' = '255,182,193',
size = '80,50',
figure = 'polygon',
_'tool.description' = 'Create new EnvironmentAgent'
class Event extends Object
attribute frequency : ecore::EInt[?] { ordered };
color = '189,183,107',
_'border.color' = '189,183,107',
size = '80,50',
figure = 'polygon',
_'polygon.x' = '10 10 60 70 60',
_'polygon.y' = '10 40 40 25 10',
_'tool.description' = 'Create new Event'
class Entity extends Object
color = '143,188,143',
_'border.color' = '143,188,143',
size = '60,30',
figure = 'rectangle',
_'tool.description' = 'Create new Entity'
class Relationship extends Object
property relationConnObject : Object[1] { ordered };
property objectIsConnByRelation : Object[1] { ordered };
label = 'name',
source = 'relationConnObject',
target = 'objectIsConnByRelation',
color = '255,127,80',
width = '2',
_'tool.description' = 'Create new Relationship between two Objects'
class OperationNode extends Nodes
property operationNodeToOperatLink#operatLinkToOperationNode : OperationalizationLink[*] { ordered };
property operationIsPerformed#perLinkToOperationNode : PerformsLink[*] { ordered };
operation operationNumberOfAgents() : ecore::EIntegerObject[?]
body: self.operationIsPerformed->collect(perLinkToAgent)->size();
color = '211,211,211',
_'border.color' = '211,211,211',
size = '60,30',
figure = 'ellipse',
_'tool.description' = 'Create new OperationNode'
color = '0,0,255',
width = '2',
style = 'dash',
color = '0,0,255',
width = '2',
width = '2',
width = '2',
color = '0,139,0',
width = '2',
class OperationalizationLink extends Links
attribute label : String[1] = 'Operationalization' { ordered readonly };
property operatLinkToGoal#goalToOperatLink : Goal[1] { ordered };
property operatLinkToOperationNode#operationNodeToOperatLink : OperationNode[1] { ordered };
label = 'label',
source = 'operatLinkToGoal',
target = 'operatLinkToOperationNode',
color = '105,105,105',
width = '2',
_'tool.description' = 'Create new OperationalizationLink between an Operation and a Goal'
class ConcernsLink extends Links
attribute label : String[1] = 'Concerns' { ordered readonly };
property concernedByGoal#goalConcerns : Goal[1] { ordered };
property concernsObject#objectIsConcerned : Object[1] { ordered };
label = 'label',
source = 'concernedByGoal',
target = 'concernsObject',
color = '205,133,63',
width = '2',
_'tool.description' = 'Create new ConcernsLink between a Goal, Requirement or Expectation and an Object'
class DomainPropLink extends Links
property DomPropLinkToGoal#goalHasDomProp : Goal[1] { ordered };
property goalToDomProp#domPropToGoal : DomainProperties[1] { ordered };
source = 'DomPropLinkToGoal',
target = 'goalToDomProp',
color = '148,0,211',
width = '2',
'Create new DomainPropLink between Goal, Requirement or Expectation and Domain Invariant or Domain Hipothesis'
class AgentReqLink extends Links
property ReqToAgentLink#agentToReqLink : SystemAgent[1] { ordered };
property agentReqLinkToReq#ReqToAgentReqLink : Requirement[1] { ordered };
source = 'ReqToAgentLink',
target = 'agentReqLinkToReq',
color = '233,150,122',
width = '2',
_'tool.description' = 'Create new AgentReqLink for connecting a System Agent to a Requirement'
class AgentExpLink extends Links
property expLinkToAgent#agentToExpLink : EnvironmentAgent[1] { ordered };
property agentExpLinkToExp#expToAgentExpLink : Expectation[1] { ordered };
source = 'expLinkToAgent',
target = 'agentExpLinkToExp',
color = '176,48,96',
width = '2',
_'tool.description' = 'Create new AgentExpLink for connecting an Environment Agent to an Expectation'
class InheritanceLink extends Links
invariant linkToHimself('Object ' + inhLinkToObject.name + ' can not be a refinement of himself.'):
inhLinkToObject <> inhLinkToOtherObj;
property inhLinkToObject#objToInhLink : Object[1] { ordered };
property inhLinkToOtherObj#otherObjToInhLink : Object[1] { ordered };
source = 'inhLinkToObject',
target = 'inhLinkToOtherObj',
_'target.decoration' = 'closedarrow',
width = '2',
_'tool.description' = 'Create new InheritanceLink between Entities'
class AggregationLink extends Links
invariant linkToHimself('Object ' + aggLinkToObject.name + ' can not be a refinement of himself.'):
aggLinkToObject <> aggLinkToOtherObject;
property aggLinkToObject#objToAggLink : Object[1] { ordered };
property aggLinkToOtherObject#otherObjToAggLink : Object[1] { ordered };
source = 'aggLinkToObject',
target = 'aggLinkToOtherObject',
_'target.decoration' = 'filledrhomb',
width = '2',
_'tool.description' = 'Create new AggregationLink between Entities'
class CardinalityLink extends Links
attribute firstEnd : String[1] { ordered };
attribute secondEnd : String[1] { ordered };
property cardLinkToObject#objToCardLink : Object[1] { ordered };
property cardLinkToOtherObject#otherObjToCardLink : Object[1] { ordered };
source = 'cardLinkToObject',
target = 'cardLinkToOtherObject',
width = '2',
_'tool.description' = 'Create new CardinalityLink between Entities'
class MonitorsLink extends Links
attribute label : String[1] = 'Monitors' { ordered readonly };
property monLinkToAgent#agentMonitors : Agent[1] { ordered };
property monLinkToObject#objIsMonitored : Object[1] { ordered };
label = 'label',
source = 'monLinkToAgent',
target = 'monLinkToObject',
color = '102,205,170',
width = '2',
_'tool.description' = 'Create new MonitorsLink between an Object and an Agent'
class ControlsLink extends Links
attribute label : String[1] = 'Controls' { ordered readonly };
property contLinkToAgent#agentControls : Agent[1] { ordered };
property contLinkToObject#objIsControlled : Object[1] { ordered };
label = 'label',
source = 'contLinkToAgent',
target = 'contLinkToObject',
color = '34,139,34',
width = '2',
_'tool.description' = 'Create new ControlsLink between an Object and an Agent'
class PerformsLink extends Links
attribute label : String[1] = 'Performs' { ordered readonly };
property perLinkToAgent#agentPerforms : Agent[1] { ordered };
property perLinkToOperationNode#operationIsPerformed : OperationNode[1] { ordered };
label = 'label',
source = 'perLinkToAgent',
target = 'perLinkToOperationNode',
color = '0,0,0',
width = '2',
_'tool.description' = 'Create new PerformsLink between an Agent and an Operation'
class Conflict extends Links
invariant linkToHimself('Goal ' + conflictBtwnGoals.name + ' can not be a refinement of himself.'):
conflictBtwnGoals <> goalHasConflict;
attribute label : String[1] = 'Conflict' { ordered readonly };
property conflictBtwnGoals : Goal[1] { ordered };
property goalHasConflict : Goal[1] { ordered };
label = 'label',
source = 'conflictBtwnGoals',
target = 'goalHasConflict',
color = '205,0,0',
_'source.decoration' = 'arrow',
width = '2',
style = 'dash',
_'tool.description' = 'Create new Conflict between Goals'
annotation gmf
foo = 'bar'
and the problem is with the operation modelDepth
Current Time: Thu Aug 21 20:44:58 EDT 2025
Powered by FUDForum. Page generated in 0.07506 seconds
