Home » Language IDEs » PHP Development Tools (PDT) » Setup Eclipse php environment
Setup Eclipse php environment [message #783917] Thu, 26 January 2012 13:23 Go to next message
I'm trying to setup an eclipse php development environment and following this instruction: docs.joomla.org/Setting_up_your_workstation_for_Joomla!_development#Edit_PHP.INI_File
I already installed eclipse with pdt 3.0.x
After that i installed xampp 1.7.7 and make some changes to the php.ini to use xdebug.
So far everything seems ok.
But than i'm trying to make a test php project.
The problem i now have is configure the php server. Because the screen shows on this instruction is from an older version of eclipse i think.
I now don't know what i have to fill in with the Server properties "Base URL" and "Local Web Root".
I tried for the base url = "//localhost:10000" and for local web root = "D:\xampp\htdocs\Joomla_development". In this Joomla_development directory i placed the directory with the Test Debug project. I also add a path mapping. path on server = "D:\xampp\htdocs\Joomla_development" and path in workspace = "/Test Debug".
When i now try to run the test.php as a PHP web page, Firefox opens but it doesn't come up with my test page. Instead it shows "Object not found the url wasn't found on this server error 404". In the address said : //localhost/Test, but my project calls Test Debug and my page is test.php
On a second tab in firefox the message shows "An unexpected problem has occured with the application. UPDATE `ubh_settings` SET global_code = '' WHERE setting_id = '1'"
Maybe someone can help me with my problem ?
[Updated on: Thu, 26 January 2012 13:28] by Moderator
Re: Setup Eclipse php environment [message #784280 is a reply to message #783917] Fri, 27 January 2012 04:38 Go to previous messageGo to next message
Almost 200 views and nobody can help me ?
Re: Setup Eclipse php environment [message #784475 is a reply to message #783917] Fri, 27 January 2012 10:31 Go to previous message
> this instruction:
> to use xdebug.
> URL" and "Local Web Root". I tried for the base url = "localhost:10000"
Perhaps you could mention what URL it was trying to load? I'm surprised
that you wouldn't use d:\xampp\htdocs as the root.
Nitin Dahyabhai
Eclipse WTP Source Editing and JSDT
IBM Rational
Previous Topic:Advanced Debugging for a complex PHP project
Next Topic:Projects mngt organization basis for a newbie Eclipse user
Current Time: Sat Jul 26 03:38:47 EDT 2025
Powered by FUDForum. Page generated in 0.03989 seconds
