Re: [Acceleo] - Help with a small exercise. [message #780505 is a reply to message #780452] |
Wed, 18 January 2012 11:03 |
It would indeed be something easy for one of us... but the point of your exercise is not to have someone do your homework for you. Rather to make you discover a new tool... and teach you how to learn by yourself as you will most likely have to do in your professional life .
As for how to create the generator, please try and follow the Getting Started guide and try to at least get a first basic draft of what you need. We will help if you hit a wall .
Laurent Goubet
Obeo
Re: [Acceleo] - Help with a small exercise. [message #780641 is a reply to message #780452] |
Wed, 18 January 2012 20:52 |
Davide Perini Messages: 28 Registered: January 2012 |
this is a common problem seen in many excercises, unfortunantly I have never seen someone posting a solution to this commond problem.
have you founded some solution to the problem?
I have a working environment, I have generated a mtl that can print all class names and all methods of the classes.
But how can I see what class extends what class, aggregation, inference, if a class is abstract ecc ecc. ?
[Updated on: Sat, 21 January 2012 13:05] Report message to a moderator
FUDForum. Page generated in 0.03541 seconds
