Re: Scatter Charts facilities - full freedom? [message #774356 is a reply to message #773799] |
Tue, 03 January 2012 19:01 |
Stein,
Currently BIRT charts can only be bound to one dataset. Although you
can combine many datasets into one using the joint dataset feature, I am
not sure that will help in this case. You can also use scripting to
setup a javascript array of x and y values that can be retrieved from
many datasets. This approach is a bit more complicated but can be done.
The only caveat is that you have to have the same number of x and y
values. If this is something you are interested in I can help with an
example.
Jason
On 1/2/2012 10:14 AM, Stein Erik wrote:
> I am looking at producing scatter charts where all the different x-y
> datasets have full freedom from each other. But I cannot figure it out
> for BIRT.
> I would for example like to display 5 datasets in the same scatter chart
> (sharing the same axes and units though). These 5 sets of many x-y pairs
> all have these characteristics: (i) different number of x values, (ii)
> the x-values are not identical/shared between the datasets, and (iii)
> the y-values are of course not shared between the different 5 datasets.
> This situation is common for scientific/engineering purposes. Just as
> examples; spreadsheets like Excel and OpenOffice provide such facilities
> with ease, and I have produced similar charts with some other graphical
> packages on other platforms.
> Hopefully there is a easy way to guide me through. And if such
> functionalities do not exist at the moment, please let me know that too!
> Thanks in advance!
> Best,
> Stein Erik
Re: Scatter Charts facilities - full freedom? [message #774365 is a reply to message #774356] |
Tue, 03 January 2012 19:24 |
Stein Erik Messages: 9 Registered: September 2011 |
Thx so much for the clear and elaborate answer Jason.
The capability I was looking for is essential for the charting part of my application, so I will for now try another charting package which meets that requirement. Unfortunately, that will "hurt" the integration to my data in the EMF datastore and other nice report & charting capabilities BIRT offer. Can´t win them all...
[Updated on: Tue, 03 January 2012 19:25] Report message to a moderator
Re: Scatter Charts facilities - full freedom? [message #774823 is a reply to message #774365] |
Wed, 04 January 2012 17:53 |
If you want an example of building a chart dataset from multiple report
datasets using script let me know.
Jason
> The scatter chart capability I was looking for is essential for the
FUDForum. Page generated in 0.02894 seconds
