space in java editor does now show properly [message #769044] |
Wed, 21 December 2011 10:00 |
anfernee Messages: 1 Registered: December 2011 |
I'm using Eclipse Indigo Service Release 1 on my ubuntu(64bit, 11.0.6), I'm seeing some code format issue in my java editor, for example I enter 5 space characters in the first line, so the cursor show me at 1:5, and then I move to the next line and still enter 5 space characters, the cursor position moves to 2:5 as expected, but it's far more behind the last line, it makes the UI ugly.
FYI, if I copy the same file to other machine, it looks good, I also tried with Eclipse 3.6, it also looks bad, does anyone has some clue what's wrong with my setup?
Anfernee
Re: space in java editor does now show properly [message #775578 is a reply to message #769044] |
Fri, 06 January 2012 09:51 |
Dani Megert Messages: 3802 Registered: July 2009 |
Does it insert spaces or maybe tab(s)? If the latter, you probably don't
have a monospace font set.
Dani
> Thanks
> Anfernee
FUDForum. Page generated in 0.03522 seconds
