Re: Know the Co-ordinates [message #753673 is a reply to message #753476] |
Fri, 28 October 2011 09:56 |
Maqsood Ahmed Messages: 41 Registered: September 2010 |
Member |
ContainerShape shapeToMove = (ContainerShape) context.getPictogramElement();
Object obj = getBusinessObjectForPictogramElement(shapeToMove);
if (obj instanceof A || obj instanceof B|| obj instanceof C) {
ContainerShape container = shapeToMove.getContainer();
int containerWidth = container.getGraphicsAlgorithm().getWidth();
int containerHeight = container.getGraphicsAlgorithm().getHeight();
int shapeWidth = shapeToMove.getGraphicsAlgorithm().getWidth();
int shapeHeight = shapeToMove.getGraphicsAlgorithm().getHeight();
int shapeX = context.getX();
int shapeY = context.getY();
EList<Shape> children = container.getChildren();
for (Shape node : children) {
if (node instanceof ContainerShape && node != shapeToMove) {
int nodeX = node.getGraphicsAlgorithm().getX();
int nodeY = node.getGraphicsAlgorithm().getY();
int nodeWitdth = node.getGraphicsAlgorithm().getWidth();
int nodeHeight = node.getGraphicsAlgorithm().getHeight();
if ((nodeY < shapeY && nodeY + nodeHeight > shapeY) || (nodeY > shapeY && shapeY + shapeHeight > nodeY)) {
if (shapeX > nodeX && shapeX < nodeX + nodeWitdth) {
System.out.println("FC == 1");
return false;
if (shapeX == nodeX) {
System.out.println("FC == 2");
return false;
if (shapeX < nodeX && shapeX + shapeWidth > nodeX) {
System.out.println("FC == 3");
return false;
} else if (nodeY == shapeY) {
if (nodeX < shapeX && nodeX + nodeWitdth > shapeX) {
System.out.println("FC == 4");
return false;
if (nodeX == shapeX || nodeX + nodeWitdth == shapeX + shapeWidth) {
System.out.println("FC ==5");
return false;
if (nodeX > shapeX && shapeX + shapeWidth < nodeX) {
System.out.println("FC == 6");
return false;
// move towards right
if ((shapeX + shapeWidth) > containerWidth) {
System.out.println("move Right");
return false;
// move towards left
if (shapeX < 0) {
System.out.println("move left");
return false;
// move towards bottom
if ((shapeY + shapeHeight) > containerHeight) {
System.out.println("bottom");
return false;
// move towards top;
if (shapeY < 30) {
System.out.println("top");
return false;
// if (shapeX + shapeWidth < GraphitiUtil.getCurrentGraphicalViewer().getDiagram().getChildren().get(0).getGraphicsAlgorithm().getWidth())
// shapeToMove.getGraphicsAlgorithm().get
// System.out.println("core");
// return false;
return true;
I have put system.out.print.. to knw the co-ordinates while i am holding(moving) the shape inside another shape completely.
Pls note : container is diagram , the above code checks generically if a shapeToMove can be moved to a new position taking into account all other diagram childern.
[Updated on: Fri, 28 October 2011 10:12] Report message to a moderator
Re: Know the Co-ordinates [message #753946 is a reply to message #753676] |
Mon, 31 October 2011 06:27 |
Member |
Hi Andread,
Thanks for your reply. It was really useful, I din't notice that the was available in the context.
I have adapted accordingly.
Solved
Move Shape into another shape completely, check using context.getTargetContainer()
and you can return false where you do not want to allow.
You will have to restrict based on co-ordinates when moving within the same container(adding some padding etc..)
Mak
[Updated on: Mon, 31 October 2011 06:34] Report message to a moderator
FUDForum. Page generated in 0.03217 seconds
