Home » Eclipse Projects » Eclipse Platform » Way to have one close button for all tabs?
Way to have one close button for all tabs? [message #76611] Tue, 17 June 2003 13:53 Go to next message
Originally posted by: stevenyi.hellokitty.com
Hi all,
I was wondering if there is any configuration setting for having one close
button for all tabs instead one per tab for the main text editor area. I'm
thinking along the lines of the netscape browser where there is one x that
will close whatever is the active tab. I find I often have quite a few
files open and find it near impossible to read what each tab is, and I
figured if there was a way to use only one close button that it would free
up realestate for showing the title of the tab.
steven
Re: Way to have one close button for all tabs? [message #76803 is a reply to message #76611] Tue, 17 June 2003 15:29 Go to previous messageGo to next message
Originally posted by: richkulp.NOSPAM.us.ibm.com
ctrl+shift+W will bring up a list of all open editors. From there you
can select any number of them that you want and close them all at once.
Rich
Re: Way to have one close button for all tabs? [message #76881 is a reply to message #76803] Tue, 17 June 2003 16:08 Go to previous messageGo to next message
Oh, didn't know about this, but it's a bit of a usability slowdown for me to
have to pop open a window to navigate. It's nice to have this though for
closing multiple documents.
So I guess I'm stuck with illegible tabs. =( I wish there was a way to
restict how small the tabs could get, but I couldn't find that anywhere
either. This is really my only gripe about eclipse to date, so I'm really
wanting to find a way.
Thanks Richard,
steven
"Richard L. Kulp" <richkulp@NOSPAM.us.ibm.com> wrote in message
news:bcnq9j$2fb$2@rogue.oti.com...
> Rich
Re: Way to have one close button for all tabs? [message #76913 is a reply to message #76881] Tue, 17 June 2003 16:49 Go to previous messageGo to next message
Originally posted by: bdeweese.yahoo.com
Some of the 2.1 milestone releases supported variable tab compression
via preferences but it was removed. You can still get it though by
editing a configuration file. I don't know if this will work in 3.0.
In the "plugins\org.eclipse.platform_2.1.0\plugin_customization.ini "
file, add/edit these lines.
# EditorList Pulldown - activate by setting to true.
org.eclipse.ui.workbench/EDITORLIST_PULLDOWN_ACTIVE=true
# TabCompression - specify the amount of compression to use on the
# editor tabs. The value is multiplied by the font height and used as
# the maximum width of the tab. So a smaller number will compress more.
# Use a large number, such as 30, to turn off tab compression.
# Typical values are: high=3, medium=6, low=9, none=30
org.eclipse.ui.workbench/EDITOR_TAB_WIDTH=8
> Thanks Richard,
> steven
>>Rich
Re: Way to have one close button for all tabs? [message #77025 is a reply to message #76881] Tue, 17 June 2003 18:17 Go to previous messageGo to next message
You can restrict the number of open editors. Eclipse will close the
editor of least recently used file. Go to
Windows->Preferences->Workbench->Editors and check Close editors
automatically. You can then enter the maximum number of editors that you
want open.
> Thanks Richard,
> steven
> > Rich
Re: Way to have one close button for all tabs? [message #77169 is a reply to message #77025] Tue, 17 June 2003 20:22 Go to previous messageGo to next message
Sorry, I think I replied directly to Brian, but his solution worked well for
me. It helps a lot. I think having a single close button would still be
the best, but Brian's solution works fine for me now.
Thanks Dave for your sugesstion as well!
steven
"Dave Wegener" <wegener@cboenospam.com> wrote in message
news:bco41j$bvl$1@rogue.oti.com...
me to
for
really
> want open.
> > Thanks Richard,
> > steven
once.
> > > Rich
Re: Way to have one close button for all tabs? [message #77370 is a reply to message #77169] Wed, 18 June 2003 03:07 Go to previous messageGo to next message
Originally posted by: tom.eicher.gmx.ch.nodomain
there is also File->Close All (Ctrl+Shift+F4) which might give you a quick
way to do what you want.
-tom
"steven" <stevenyi@hellokitty.com> wrote in message
news:bcoal1$g7g$1@rogue.oti.com...
for
> steven
> me to
> for
to
anywhere
> really
you
> > want open.
> > > Thanks Richard,
> > > steven
you
> once.
> > > > Rich
Re: Way to have one close button for all tabs? [message #77469 is a reply to message #76611] Wed, 18 June 2003 04:26 Go to previous messageGo to next message
Originally posted by: faust.acm.org
ctrl-shift-f4
Randy
news:bcnjqt$rip$1@rogue.oti.com...
> Hi all,
I'm
> steven
Re: Way to have one close button for all tabs? [message #77511 is a reply to message #76611] Wed, 18 June 2003 06:17 Go to previous messageGo to next message
I've got a patch which drastically cuts down on the space taken up on
each tab, at the expense of a little bit of accessibility (although
it's configurable). Basically it allows you to get rid of the file
extension and the icon, which saves quite a bit of space.
Let me know if you'd like a copy of the patch. I haven't done it for
3.0M1 yet, as I'm still using 2.1, but I'm sure I could whip something
up if people were interested.
Jon Skeet - <skeet@pobox.com>
http://www.pobox.com/~skeet/
If replying to the group, please do not mail me too
Re: Way to have one close button for all tabs? [message #77626 is a reply to message #76611] Wed, 18 June 2003 08:46 Go to previous messageGo to next message
Originally posted by: mxlehma.NO-SPAM.qwest.com
steven wrote:
> Hi all,
> steven
I too would love to see this added as a feature in 3.0. I don't know
how many times I would go to select a particular tab and inadvertently
close the file or an adjacent tab because of a brief interruption in
mouse movement. I know other editors like Visual Studio .Net provide a
single close button on the left. This leaves alot more room for the
file names.
Having variable size tabs and/or stacking the tabs on multiple lines may
be another solution. Also having a preference that would allow me to
remove the icon from being displayed on tab would be great.
Michael
Re: Way to have one close button for all tabs? [message #77937 is a reply to message #77370] Wed, 18 June 2003 13:45 Go to previous message
Oh sorry, I'm not wanting to close all tabs, but just have one close button
around that will work on the active tab. If you look at netscape/mozilla
and to tabbed browsing, you'll see multiple tabs added but the close button
is fixed at the far right. when you press the close button, it only closes
the active tab.
If this was implemented this way on Eclipse, it would free up some room on
the tabs to view the filenames as not every tab would need to have it's own
close button (some 20-30 pixels per tab, which adds up quickly).
You might want to check out:
http://channels.netscape.com/ns/browsers/browsing.jsp#br2
to see what the tabs look like (the picture doesn't show the close button to
the far right).
Also, implementing bookmarks like mozilla/netscape does would be nice, so
you could bookmark a single file or a group of files.
thanks,
steven
"Tom Eicher" <tom.eicher@gmx.ch.nodomain> wrote in message
news:bcp30k$vcl$1@rogue.oti.com...
> -tom
> for
be
> > steven
Previous Topic:Writing to the status line
Next Topic:Third mouse button under X11
Current Time: Sat Oct 04 15:31:05 EDT 2025
Powered by FUDForum. Page generated in 0.04698 seconds
