Re: AJDT 2.0.0 + Eclipse 3.5 ClassNotFoundException [message #74300 is a reply to message #74281] |
Mon, 29 June 2009 17:38 |
Originally posted by: andrew.eisenberg.springsource.com
The important part of the exception stack trace is below. This says that
for some reason, ICompilerConfiguration was not found. And this cascades to
a bunch of other exceptions, first that the ajdt.core plugin cannot be
started, and then that AJSourceTransformer cannot be loaded (because its
plugin cannot be started).
I am not sure why ICompilerConfiguration cannot be found. But it is
possible that your ajdt installation failed in some way and therefore the
org.aspectj.ajde plugin cannot be loaded.
Did you have any problems with installation or do you have any other errors
in your error log?
On 29/06/09 8:59 AM, in article
d4d52d0fc34d9d024e7889129299d9a7$1@www.eclipse.org, "Fu Zebest"
<fuzebest@mail.ru> wrote:
> Caused by: java.lang.ClassNotFoundException:
> org.aspectj.ajde.core.ICompilerConfiguration
> at
> org.eclipse.osgi.internal.loader.BundleLoader.findClassInter nal(BundleLoader.j
> ava:489)
> at
> org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:405)
> at
> org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:393)
> at
> org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClas
> sLoader.java:105)
> at java.lang.ClassLoader.loadClass(ClassLoader.java:252)
> at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:320 )
> ... 75 more
Re: AJDT 2.0.0 + Eclipse 3.5 ClassNotFoundException [message #74334 is a reply to message #74317] |
Tue, 30 June 2009 17:17 |
The plugin is org.aspectj.ajde.
Make sure that the plugin is installed and the version should be
1.6.5.20090618034232 (although if it is a slightly different version, should
be OK). Also, make sure that the class exists inside of that plugin.
Did you install through the update site or through a zip file?
On 30/06/09 1:14 AM, in article
99d22748aae8ee9183f4ccd56a4dd516$1@www.eclipse.org, "Fu Zebest"
>> in your error log?
> No there was no problem with a clean Eclipse installation with a clean
> workspace.
> The log file is filled with the exception stacktraces all rooted to the
> org.aspectj.ajde.core.ICompilerConfiguration.
> Even more weird thing - I cannot find this class anywhere in my Eclipse
> installation. Which plugin contains it?
> Forgot to mention the exact AJDT version - 2.0.0.e35x-20090625-1000.
FUDForum. Page generated in 0.04191 seconds
