Home » Language IDEs » AspectJ » Systematic full build - AJDT 2.1.2, Eclipse 3.6(Need help, why AJDT rebuilds everything systematically?)
Systematic full build - AJDT 2.1.2, Eclipse 3.6 [message #686060] |
Tue, 21 June 2011 14:37 |
John Rizzo Messages: 2 Registered: June 2011 |
Hi guys,
I'm very happy novice user of AJDT for 2 years, but now I stuck with the following.
On my newly installed machine (Win7-64) with Eclipse Helios and AJDT, my projects rebuilds when I save any change. It takes ages.
The AJDT trace is below.
Here are my installed plugins and versions: screencast.com/t/NPkPKTIGezT
I tried touching a file that is not @Configurable, but it's the same.
It seems like AJDT detects it's about that file, recompiles it, then thinks it should recompile all others to a full build.
My co-worker does not have that behavior.
Any idea for me (else than trying to install older versions) ?
Many thanks!
16:15:42 AspectJ reports build successful, build was: FULL
16:15:42 AJDE Callback: finish. Was full build: true
16:15:42 Timer event: 26954ms: Total time spent in AJDE
16:15:42 Timer event: 0ms: Refresh after build
16:15:42 Types affected during build = 1357
16:15:43 Timer event: 27711ms: Total time spent in AJBuilder.build()
16:15:43 Timer event: 0ms: Update visualizer, xref, advice listeners for (separate thread): JavaBlackBelt
16:15:43 Timer event: 316ms: Delete markers: JavaBlackBelt (Finished deleting markers for JavaBlackBelt)
16:15:44 Timer event: 1211ms: Create markers: JavaBlackBelt (Finished creating markers for JavaBlackBelt)
16:15:44 Created 702 markers in 1357 files
16:15:44 ===========================================================================================
16:15:44 Build kind = AUTOBUILD
16:15:44 Project=JavaBlackBelt, kind of build requested=Incremental AspectJ compilation
16:15:44 Timer event: 0ms: Flush included source file cache
16:15:44 Timer event: 6ms: Check delta
16:15:44 File: C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\parser\BlackBeltTagParser.java has changed.
16:15:44 build: Examined delta - 1 changed, 0 added, and 0 deleted source files in required project JavaBlackBelt
16:15:44 Timer event: 4ms: Looking for and marking configuration changes in JavaBlackBelt
16:15:44 Configuration changes found: true
16:15:44 Timer event: 4ms: Look for source/resource changes
16:15:44 Setting list of classpath elements with modified contents:
16:15:44 [C:/javadev/prj/JavaBlackBelt/externallib/junit.jar, C:/javadev/prj/JavaBlackBelt/externallib/spring-mock.jar, C:/javadev/prj/JavaBlackBelt/externallib/easymock.jar, C:/javadev/prj/JavaBlackBelt/externallib/ant-launcher.jar, C:/javadev/prj/JavaBlackBelt/externallib/mockito-all-1.2.jar, C:/javadev/prj/JavaBlackBelt/externallib/testng-5.7-jdk15.jar, C:/javadev/prj/JavaBlackBelt/externallib/tomcat-juli.jar, C:/javadev/prj/JavaBlackBelt/externallib/fest-reflect-0.4.jar, C:/javadev/prj/JavaBlackBelt/externallib/fest-util-0.4.jar, C:/javadev/prj/JavaBlackBelt/WebRoot/WEB-INF/lib, C:/javadev/prj/JavaBlackBelt/externallib/gwt-user.jar, C:/javadev/prj/JavaBlackBelt/externallib/gwt-dev.jar, C:/javadev/prj/JavaBlackBelt/WebRoot/WEB-INF/lib/org.springframework.aspects-3.0.4.RELEASE.jar]
16:15:44 Timer event: 19ms: Pre compile
16:15:44 Sending the following configuration changes to the compiler: []
16:15:44 1 source file changes since last build
16:15:44 Compiler configuration for project JavaBlackBelt has been read by compiler. Resetting.
16:15:44 Configuration was []
16:15:44 Resetting list of modified source files. Was [C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\parser\BlackBeltTagParser.java]
16:15:44 ClassFileChangeChecking: failed to find a state instance managing output location : C:\javadev\prj\JavaBlackBelt\WebRoot\WEB-INF\lib
16:15:44 ClassFileChangeChecking: queried JDT and 'C:\javadev\prj\JavaBlackBelt\WebRoot\WEB-INF\lib' is apparently unchanged so not performing timestamp check
16:15:44 Preparing for build: planning to be an incremental build
16:15:44 Starting incremental compilation loop 1 of possibly 5
16:15:45 Timer event: 140ms: Time to first compiled message
16:15:45 Timer event: 144ms: Time to first woven message
16:15:45 Examining whether any other files now need compilation based on just compiling: '{C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\parser\BlackBeltTagParser.java}'
16:15:45 Need to recompile 'IndexManagerService.java'
16:15:45 Need to recompile 'QuestionImageService.java'
16:15:45 Need to recompile 'AnswerLines.java'
16:15:45 Need to recompile 'BlackBeltTagHandlerStringGenerator.java'
16:15:45 Need to recompile 'QuestionPage.java'
16:15:45 Need to recompile 'CoursePage.java'
16:15:45 Need to recompile 'BlackBeltTagHandler.java'
16:15:45 Need to recompile 'CourseXmlGenerator.java'
16:15:45 Need to recompile 'QuestionPanel.java'
16:15:45 Need to recompile 'BlackBeltTagHandlerCourseOnBrowser.java'
16:15:45 Need to recompile 'BlackBeltTagHandlerCourseOnXml.java'
16:15:45 Need to recompile 'BlackBeltTagHandlerQuestionCodeImageCreation.java'
16:15:45 Need to recompile 'NudeMain.java'
16:15:45 Need to recompile 'SectionComponent.java'
16:15:45 Need to recompile 'QuestionTextLabel.java'
16:15:45 Need to recompile 'ImageDemoPage.java'
16:15:45 Need to recompile 'BlackBeltTagHandlerCourseOnPdf.java'
16:15:45 Need to recompile 'BlackBeltTagHandlerQuestionCodeImageDisplay.java'
16:15:45 Need to recompile 'BlackBeltTagHandlerQuestionCodeText.java'
16:15:45 Need to recompile 'CoursePdfGenerator.java'
16:15:45 Need to recompile 'BlackBeltTagHandlerCourse.java'
16:15:45 Need to recompile 'BlackBeltTagHandlerLuceneSearch.java'
16:15:45 Starting incremental compilation loop 2 of possibly 5
16:15:45 Examining whether any other files now need compilation based on just compiling: '{C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\service\IndexManagerService.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\parser\BlackBeltTagHandlerCourseOnBrowser.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\question\AnswerLines.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\parser\BlackBeltTagHandlerStringGenerator.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\service\QuestionImageService.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\parser\BlackBeltTagHandlerQuestionCodeImageDisplay.java,C:\javadev\prj\JavaBlackBelt\src\main\java\be\loop\jbb\batch\old\NudeMain.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\parser\BlackBeltTagHandlerQuestionCodeImageCreation.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\pdf\CoursePdfGenerator.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\question\QuestionTextLabel.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\imageDemo\ImageDemoPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\question\QuestionPanel.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\parser\BlackBeltTagHandlerQuestionCodeText.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\parser\BlackBeltTagParser.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\xml\CourseXmlGenerator.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\parser\BlackBeltTagHandler.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\parser\BlackBeltTagHandlerLuceneSearch.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\coursepage\SectionComponent.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\parser\BlackBeltTagHandlerCourseOnPdf.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\parser\BlackBeltTagHandlerCourseOnXml.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\parser\BlackBeltTagHandlerCourse.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\question\QuestionPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\course\CoursePage.java}'
16:15:45 Need to recompile 'ConvinceYourBossWindow.java'
16:15:45 Need to recompile 'ExamResultPage.java'
16:15:45 Need to recompile 'ResultPage.java'
16:15:45 Need to recompile 'CourseRegDetailBox.java'
16:15:45 Need to recompile 'BreadCrumb.java'
16:15:45 Need to recompile 'TopicHomePageBox.java'
16:15:45 Need to recompile 'TopicPage.java'
16:15:45 Need to recompile 'ComponentFactory.java'
16:15:45 Need to recompile 'QuestionExpandablePanel.java'
16:15:45 Need to recompile 'SectionTextService.java'
16:15:45 Need to recompile 'CourseTodoService.java'
16:15:45 Need to recompile 'BlackBeltWebApplication.java'
16:15:45 Need to recompile 'TopicWithCourseExamLinks.java'
16:15:45 Need to recompile 'SiteMapGenerator.java'
16:15:45 Need to recompile 'SectionComparePage.java'
16:15:45 Need to recompile 'LangOverviewPage.java'
16:15:45 Need to recompile 'JohnTester.java'
16:15:45 Need to recompile 'AdminPage.java'
16:15:45 Need to recompile 'CourseSearchResultsManager.java'
16:15:45 Need to recompile 'PdfCourseOptionWindow.java'
16:15:45 Need to recompile 'FileServiceImpl.java'
16:15:45 Need to recompile 'TopicDetailedList.java'
16:15:45 Need to recompile 'ExamContributePage.java'
16:15:45 Need to recompile 'SectionsOnPage.java'
16:15:45 Need to recompile 'CoursePagePage.java'
16:15:45 Starting incremental compilation loop 3 of possibly 5
16:15:47 Examining whether any other files now need compilation based on just compiling: '{C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\service\IndexManagerService.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\question\AnswerLines.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\service\QuestionImageService.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\parser\BlackBeltTagHandlerQuestionCodeImageDisplay.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\service\CourseTodoService.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\common\ComponentFactory.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\search\CourseSearchResultsManager.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\question\QuestionPanel.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\parser\BlackBeltTagHandlerQuestionCodeText.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\topic\TopicWithCourseExamLinks.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\coursepage\SectionComparePage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\parser\BlackBeltTagParser.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\parser\BlackBeltTagHandler.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\coursereg\CourseRegDetailBox.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\exam\ExamResultPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\coursepage\CoursePagePage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\model\SiteMapGenerator.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\common\BreadCrumb.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\topic\TopicHomePageBox.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\parser\BlackBeltTagHandlerCourseOnBrowser.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\parser\BlackBeltTagHandlerStringGenerator.java,C:\javadev\prj\JavaBlackBelt\src\main\java\be\loop\jbb\batch\old\NudeMain.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\parser\BlackBeltTagHandlerQuestionCodeImageCreation.java,C:\javadev\prj\JavaBlackBelt\src\main\java\be\loop\jbb\batch\old\JohnTester.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\question\QuestionTextLabel.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\pdf\CoursePdfGenerator.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\imageDemo\ImageDemoPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\application\BlackBeltWebApplication.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\lang\LangOverviewPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\pdf\PdfCourseOptionWindow.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\xml\CourseXmlGenerator.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\topic\TopicDetailedList.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\course\ConvinceYourBossWindow.java,C:\javadev\prj\JavaBlackBelt\src\main\java\be\loop\jbb\bl\impl\FileServiceImpl.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\question\QuestionExpandablePanel.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\coursepage\SectionComponent.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\parser\BlackBeltTagHandlerLuceneSearch.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\topic\TopicPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\parser\BlackBeltTagHandlerCourseOnPdf.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\parser\BlackBeltTagHandlerCourseOnXml.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\service\SectionTextService.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\parser\BlackBeltTagHandlerCourse.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\question\QuestionPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\search\ResultPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\coach\AdminPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\course\CoursePage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\exam\ExamContributePage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\coursepage\SectionsOnPage.java}'
16:15:47 Need to recompile 'CourseRegApplyDetailBox.java'
16:15:47 Need to recompile 'PageUtil.java'
16:15:47 Need to recompile 'SearchDialogBox.java'
16:15:47 Need to recompile 'VideoWindow.java'
16:15:47 Need to recompile 'ExamPerformPage.java'
16:15:47 Need to recompile 'CourseRegUserPage.java'
16:15:47 Need to recompile 'TopicListPage.java'
16:15:47 Need to recompile 'AuctionService.java'
16:15:47 Need to recompile 'ForumCategoryPage.java'
16:15:47 Need to recompile 'UserDiscussionListPage.java'
16:15:47 Need to recompile 'CourseRegEventComponent.java'
16:15:47 Need to recompile 'StudentCourseRegList.java'
16:15:47 Need to recompile 'UserListPage.java'
16:15:47 Need to recompile 'CourseCommentService.java'
16:15:47 Need to recompile 'GroupMemberList.java'
16:15:47 Need to recompile 'CourseTodoPage.java'
16:15:47 Need to recompile 'ManualVerificationService.java'
16:15:47 Need to recompile 'CourseTodoList.java'
16:15:47 Need to recompile 'MailTemplateService.java'
16:15:47 Need to recompile 'CourseTranslationEventComponent.java'
16:15:47 Need to recompile 'BeltPage.java'
16:15:47 Need to recompile 'CourseTodoComponent.java'
16:15:47 Need to recompile 'MarketingQuoteAdminPage.java'
16:15:47 Need to recompile 'QuestionHistoryPage.java'
16:15:47 Need to recompile 'UserPage.java'
16:15:47 Need to recompile 'ExamPage.java'
16:15:47 Need to recompile 'SpecialtyPage.java'
16:15:47 Need to recompile 'LanguageLeadersPage.java'
16:15:47 Need to recompile 'CoachOfferingsList.java'
16:15:47 Need to recompile 'AsynchonousTasksFacade.java'
16:15:47 Need to recompile 'DocumentPage.java'
16:15:47 Need to recompile 'CoachOfferingPage.java'
16:15:47 Need to recompile 'TopicReviewerAccessService.java'
16:15:47 Need to recompile 'GroupCandidatesList.java'
16:15:47 Need to recompile 'CoachStatusBox.java'
16:15:47 Need to recompile 'Navigation.java'
16:15:47 Need to recompile 'HomePage.java'
16:15:47 Need to recompile 'NewsEventList.java'
16:15:47 Need to recompile 'CommunityPage.java'
16:15:47 Need to recompile 'InventoryUiService.java'
16:15:47 Need to recompile 'QuestionListPage.java'
16:15:47 Need to recompile 'TopicLedList.java'
16:15:47 Need to recompile 'ReminderService.java'
16:15:47 Need to recompile 'CourseToc.java'
16:15:47 Need to recompile 'GroupInvitationPage.java'
16:15:47 Need to recompile 'CoachTopicPage.java'
16:15:47 Need to recompile 'LanguageLedList.java'
16:15:47 Need to recompile 'GroupPanel.java'
16:15:47 Need to recompile 'Menu.java'
16:15:47 Need to recompile 'ManualVerificationRequesterPage.java'
16:15:47 Need to recompile 'UserGroupPage.java'
16:15:47 Need to recompile 'CourseCommentPage.java'
16:15:47 Need to recompile 'DocumentSnippet.java'
16:15:47 Need to recompile 'SocialNetworkEventComponent.java'
16:15:47 Need to recompile 'BlackBeltApplication.java'
16:15:47 Need to recompile 'SearchPanel.java'
16:15:47 Need to recompile 'ExamEventComponent.java'
16:15:47 Need to recompile 'GroupInvitationsList.java'
16:15:47 Need to recompile 'CommunityListPage.java'
16:15:47 Need to recompile 'PostList.java'
16:15:47 Need to recompile 'CourseCommentComponent.java'
16:15:47 Need to recompile 'LevelPage.java'
16:15:47 Need to recompile 'TopicLeadersPage.java'
16:15:47 Need to recompile 'RegisterPage.java'
16:15:47 Need to recompile 'UserExamsPage.java'
16:15:47 Need to recompile 'DiscussionPage.java'
16:15:47 Need to recompile 'UserInventoryPage.java'
16:15:47 Need to recompile 'QuestionEventComponent.java'
16:15:47 Need to recompile 'CoachStatusPage.java'
16:15:47 Need to recompile 'DiscussionListPage.java'
16:15:47 Need to recompile 'ReportSpamPage.java'
16:15:47 Need to recompile 'PrivilegePage.java'
16:15:47 Need to recompile 'ManualVerificationWaitingPage.java'
16:15:47 Need to recompile 'MentorshipPage.java'
16:15:47 Need to recompile 'TranslationReviewDialog.java'
16:15:47 Need to recompile 'Footer.java'
16:15:47 Need to recompile 'GroupEventComponent.java'
16:15:47 Need to recompile 'RegisterValidatePage.java'
16:15:47 Need to recompile 'UserBoardPage.java'
16:15:47 Need to recompile 'LanguageReviewerAccessService.java'
16:15:47 Need to recompile 'ForumEditorLayout.java'
16:15:47 Need to recompile 'BadgeEventComponent.java'
16:15:47 Need to recompile 'GroupPage.java'
16:15:47 Need to recompile 'UserSmallBox.java'
16:15:47 Need to recompile 'CourseCommentAddDialog.java'
16:15:47 Need to recompile 'ImageMapConfigBuilder.java'
16:15:47 Need to recompile 'BlackBeltAppLevelWindow.java'
16:15:47 Need to recompile 'SectionService.java'
16:15:47 Need to recompile 'ContributionPage.java'
16:15:47 Need to recompile 'AuctionEventComponent.java'
16:15:47 Need to recompile 'BeltSuccessEventComponent.java'
16:15:47 Need to recompile 'InventoryItemService.java'
16:15:47 Need to recompile 'RanchUserImageAndDescription.java'
16:15:47 Need to recompile 'DiscussionDetail.java'
16:15:47 Need to recompile 'CourseStatusForUser.java'
16:15:47 Need to recompile 'ExamAccessPage.java'
16:15:47 Need to recompile 'MailChangeOptionPage.java'
16:15:47 Need to recompile 'GroupSmallBox.java'
16:15:47 Need to recompile 'ExamObjectivePage.java'
16:15:47 Need to recompile 'QuestionList.java'
16:15:47 Need to recompile 'GroupListPage.java'
16:15:47 Need to recompile 'BeltService.java'
16:15:47 Need to recompile 'SectionTextTable.java'
16:15:47 Need to recompile 'TopicTempLeaderList.java'
16:15:47 Need to recompile 'V5QuestionnaireTable.java'
16:15:47 Need to recompile 'CourseTodoEventComponent.java'
16:15:47 Need to recompile 'GroupsAndUsersPage.java'
16:15:47 Need to recompile 'TopicsInSpecialty.java'
16:15:47 Need to recompile 'TopGroupsBox.java'
16:15:47 Need to recompile 'CourseLangPage.java'
16:15:47 Need to recompile 'MentorshipEventComponent.java'
16:15:47 Need to recompile 'CourseRegPage.java'
16:15:47 Need to recompile 'CourseActivityPage.java'
16:15:47 Need to recompile 'CourseTodoEditWindow.java'
16:15:47 Starting incremental compilation loop 4 of possibly 5
16:15:51 Examining whether any other files now need compilation based on just compiling: '{C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\event2\CourseTranslationEventComponent.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\question\AnswerLines.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\message\ReportSpamPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\service\InventoryUiService.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\course\CourseCommentAddDialog.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\topic\imagemap\ImageMapConfigBuilder.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\exam\ExamObjectivePage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\question\QuestionPanel.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\question\QuestionList.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\question\QuestionListPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\coursepage\SectionComparePage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\topic\TopicLedList.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\belt\BeltPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\layout\BlackBeltAppLevelWindow.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\coursetodo\CourseTodoComponent.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\quote\MarketingQuoteAdminPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\parser\BlackBeltTagHandlerStringGenerator.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\coursereg\CourseRegApplyDetailBox.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\service\SectionService.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\group\GroupListPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\lang\LangOverviewPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\topic\TopicDetailedList.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\user\PrivilegePage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\service\BeltService.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\course\CourseCommentPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\common\DocumentSnippet.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\question\QuestionPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\contrib\ContributionPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\exam\ExamContributePage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\event2\SocialNetworkEventComponent.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\manualverification\ManualVerificationWaitingPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\event2\AuctionEventComponent.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\course\SectionTextTable.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\common\PageUtil.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\parser\BlackBeltTagHandlerQuestionCodeImageDisplay.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\question\QuestionHistoryPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\application\BlackBeltApplication.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\topic\TopicTempLeaderList.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\forum\ForumCategoryPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\search\SearchPanel.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\common\ComponentFactory.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\event2\ExamEventComponent.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\coach\MentorshipPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\topic\TopicWithCourseExamLinks.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\forum\UserDiscussionListPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\parser\BlackBeltTagHandler.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\event2\CourseRegEventComponent.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\exam\V5QuestionnaireTable.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\coursereg\StudentCourseRegList.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\service\ReminderService.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\coursepage\CourseToc.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\user\UserPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\group\GroupInvitationPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\coach\CoachTopicPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\search\SearchDialogBox.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\coursepage\VideoWindow.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\question\QuestionTextLabel.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\user\UserListPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\lang\TranslationReviewDialog.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\lang\LanguageLedList.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\service\CourseCommentService.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\exam\ExamPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\course\ConvinceYourBossWindow.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\question\QuestionExpandablePanel.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\group\GroupInvitationsList.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\service\SectionTextService.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\exam\ExamPerformPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\specialty\SpecialtyPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\layout\Footer.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\coursepage\SectionsOnPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\event2\BeltSuccessEventComponent.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\service\IndexManagerService.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\community\CommunityListPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\service\QuestionImageService.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\lang\LanguageLeadersPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\service\CourseTodoService.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\event2\GroupEventComponent.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\coursereg\CourseRegUserPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\search\CourseSearchResultsManager.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\post\PostList.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\parser\BlackBeltTagHandlerQuestionCodeText.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\event2\CourseTodoEventComponent.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\parser\BlackBeltTagParser.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\coachoffering\CoachOfferingsList.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\course\CourseCommentComponent.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\belt\LevelPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\exam\ExamResultPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\RegisterValidatePage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\topic\TopicLeadersPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\common\BreadCrumb.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\user\UserBoardPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\service\InventoryItemService.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\group\GroupPanel.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\topic\TopicListPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\topic\TopicHomePageBox.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\scheduled\AsynchonousTasksFacade.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\user\RanchUserImageAndDescription.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\document\DocumentPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\coach\CoachOfferingPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\group\GroupsAndUsersPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\layout\Menu.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\parser\BlackBeltTagHandlerQuestionCodeImageCreation.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\group\TopGroupsBox.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\specialty\TopicsInSpecialty.java,C:\javadev\prj\JavaBlackBelt\src\main\java\be\loop\jbb\batch\old\JohnTester.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\RegisterPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\pdf\CoursePdfGenerator.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\application\BlackBeltWebApplication.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\imageDemo\ImageDemoPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\exam\UserExamsPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\pdf\PdfCourseOptionWindow.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\forum\DiscussionPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\be\loop\jbb\bl\impl\FileServiceImpl.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\topic\TopicPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\parser\BlackBeltTagHandlerCourseOnPdf.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\service\TopicReviewerAccessService.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\service\LanguageReviewerAccessService.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\lang\CourseLangPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\parser\BlackBeltTagHandlerCourse.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\search\ResultPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\event2\MentorshipEventComponent.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\group\GroupMemberList.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\coursereg\CourseRegPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\forum\ForumEditorLayout.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\inventory\UserInventoryPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\coursetodo\CourseTodoPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\event2\QuestionEventComponent.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\group\GroupCandidatesList.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\event2\DiscussionDetail.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\manualverification\ManualVerificationRequesterPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\coursereg\CourseStatusForUser.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\coach\CoachStatusBox.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\event2\BadgeEventComponent.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\coursepage\Navigation.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\exam\ExamAccessPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\coursereg\CourseRegDetailBox.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\coursepage\CoursePagePage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\model\SiteMapGenerator.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\group\UserGroupPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\HomePage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\service\ManualVerificationService.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\parser\BlackBeltTagHandlerCourseOnBrowser.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\event2\NewsEventList.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\group\GroupPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\course\CourseActivityPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\service\MailChangeOptionPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\community\CommunityPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\be\loop\jbb\batch\old\NudeMain.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\coursetodo\CourseTodoEditWindow.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\user\UserSmallBox.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\coursetodo\CourseTodoList.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\coach\CoachStatusPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\xml\CourseXmlGenerator.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\group\GroupSmallBox.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\forum\DiscussionListPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\parser\BlackBeltTagHandlerLuceneSearch.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\coursepage\SectionComponent.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\parser\BlackBeltTagHandlerCourseOnXml.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\service\MailTemplateService.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\service\AuctionService.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\coach\AdminPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\course\CoursePage.java}'
16:15:51 Need to recompile 'ForumCategoryLayout.java'
16:15:51 Need to recompile 'AuctionListing.java'
16:15:51 Need to recompile 'InventoryItemActivateOnGroupWindow.java'
16:15:51 Need to recompile 'InventoryItemPictureUploadWindow.java'
16:15:51 Need to recompile 'MarketingHomePageBox.java'
16:15:51 Need to recompile 'CourseRegService.java'
16:15:51 Need to recompile 'QuestionServiceImpl2.java'
16:15:51 Need to recompile 'DeploymentBanner.java'
16:15:51 Need to recompile 'PreviewQuestionWindow.java'
16:15:51 Need to recompile 'EditForumPage.java'
16:15:51 Need to recompile 'LoginWindow.java'
16:15:51 Need to recompile 'ManualVerificationReferenceEditWindow.java'
16:15:51 Need to recompile 'MenuNavigationForum.java'
16:15:51 Need to recompile 'EditQuestionWindow.java'
16:15:51 Need to recompile 'UserServiceImpl.java'
16:15:51 Need to recompile 'CoachOfferingBox.java'
16:15:51 Need to recompile 'ContributionServiceImpl.java'
16:15:51 Need to recompile 'CreateEditAuctionWindow.java'
16:15:51 Need to recompile 'CategoryLine.java'
16:15:51 Need to recompile 'AuctionTable.java'
16:15:51 Need to recompile 'ManualVerificationJobAdAcceptWindow.java'
16:15:51 Need to recompile 'CourseAdminPanel.java'
16:15:51 Need to recompile 'UserColumnGenerator.java'
16:15:51 Need to recompile 'MentorshipBox.java'
16:15:51 Need to recompile 'CategorySelector2.java'
16:15:51 Need to recompile 'AuctionEdit.java'
16:15:51 Need to recompile 'RegisterAndJoinGroupWindow.java'
16:15:51 Need to recompile 'MarketingMailService.java'
16:15:51 Need to recompile 'SaveToPDFLink.java'
16:15:51 Need to recompile 'DiscussionLayout.java'
16:15:51 Need to recompile 'DeletePostWindow.java'
16:15:51 Need to recompile 'UserDeleteWindow.java'
16:15:51 Need to recompile 'UserPictureUploadWindow.java'
16:15:51 Need to recompile 'UploadComponent.java'
16:15:51 Need to recompile 'DiscussionService.java'
16:15:51 Need to recompile 'PostLayout.java'
16:15:51 Need to recompile 'ManualVerificationJobAdEditWindow.java'
16:15:51 Need to recompile 'UserVideoEditWindow.java'
16:15:51 Need to recompile 'EventComponent.java'
16:15:51 Need to recompile 'CourseRegTable.java'
16:15:51 Need to recompile 'ContributionManager.java'
16:15:51 Need to recompile 'AttachmentWindow.java'
16:15:51 Need to recompile 'NextButtonPanel.java'
16:15:51 Need to recompile 'AuctionDetail.java'
16:15:51 Need to recompile 'ManualVerificationVideoAcceptWindow.java'
16:15:51 Need to recompile 'CourseDeleteWindow.java'
16:15:51 Need to recompile 'BidEdit.java'
16:15:51 Need to recompile 'SendItemModalWindow.java'
16:15:51 Need to recompile 'GroupGrid.java'
16:15:51 Need to recompile 'ManualVerificationReferenceAcceptWindow.java'
16:15:51 Need to recompile 'MailingTestPage.java'
16:15:51 Need to recompile 'CourseRegCreateForCourseWindow.java'
16:15:51 Need to recompile 'SpecialtyService.java'
16:15:51 Need to recompile 'ChangeBackgroundImageWindow.java'
16:15:51 Need to recompile 'Header.java'
16:15:51 Need to recompile 'ReactivatePage.java'
16:15:51 Need to recompile 'V5QuestionVersionDao.java'
16:15:51 Need to recompile 'MoveQuestionWindow.java'
16:15:51 Need to recompile 'CourseRegDebriefing.java'
16:15:51 Need to recompile 'SmallSeparatedLinks.java'
16:15:51 Need to recompile 'ExamServiceImpl.java'
16:15:51 Need to recompile 'UserGrid.java'
16:15:51 Need to recompile 'ManualVerificationTable.java'
16:15:51 Need to recompile 'MailSender.java'
16:15:51 Need to recompile 'QuestionAnswerStatusGrid.java'
16:15:51 Need to recompile 'AuctionClosingJob.java'
16:15:51 Need to recompile 'CourseService.java'
16:15:51 Need to recompile 'CreateSectionModalWindow.java'
16:15:51 Need to recompile 'CourseEvaluationService.java'
16:15:51 Need to recompile 'MiniUserList.java'
16:15:51 Need to recompile 'WindowUtil.java'
16:15:51 Need to recompile 'LoginCorner.java'
16:15:51 Need to recompile 'FinTransactionTable.java'
16:15:51 Need to recompile 'SaveToXmlLink.java'
16:15:51 Need to recompile 'UserNickNameEditWindow.java'
16:15:51 Need to recompile 'LastAuctions.java'
16:15:51 Need to recompile 'BLFacade.java'
16:15:51 Need to recompile 'MentorshipService.java'
16:15:51 Need to recompile 'GroupService.java'
16:15:51 Need to recompile 'TopicLeaderList.java'
16:15:51 Need to recompile 'NotificationUtil.java'
16:15:51 Need to recompile 'ActivateItemOnGroupWindow.java'
16:15:51 Need to recompile 'ModerationService.java'
16:15:51 Need to recompile 'InventoryItemActivateOnUserWindow.java'
16:15:51 Need to recompile 'TopicDescriptionBox.java'
16:15:51 Need to recompile 'GroupHierarchyTree.java'
16:15:51 Need to recompile 'ManualVerificationEditWindow.java'
16:15:51 Need to recompile 'PageAccessTraceLogInterceptor.java'
16:15:51 Need to recompile 'ManualVerificationRejectWindow.java'
16:15:51 Need to recompile 'QuestionVersionDaoImpl.java'
16:15:51 Need to recompile 'MessageSendWindow.java'
16:15:51 Starting incremental compilation loop 5 of possibly 5
16:15:56 Examining whether any other files now need compilation based on just compiling: '{C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\service\CourseService.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\group\GroupGrid.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\event2\CourseTranslationEventComponent.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\manualverification\ManualVerificationReferenceAcceptWindow.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\course\CourseCommentAddDialog.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\topic\imagemap\ImageMapConfigBuilder.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\forum\ForumCategoryLayout.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\coursepage\SectionComparePage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\user\UserDeleteWindow.java,C:\javadev\prj\JavaBlackBelt\src\main\java\be\loop\jbb\web\ww\actions\AuctionListing.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\inventory\InventoryItemActivateOnGroupWindow.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\belt\BeltPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\layout\BlackBeltAppLevelWindow.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\coursepage\CreateSectionModalWindow.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\coursetodo\CourseTodoComponent.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\inventory\InventoryItemPictureUploadWindow.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\quote\MarketingQuoteAdminPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\service\CourseEvaluationService.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\coursereg\CourseRegApplyDetailBox.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\service\SectionService.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\test\MailingTestPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\lang\LangOverviewPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\about\MarketingHomePageBox.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\topic\TopicDetailedList.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\coursereg\CourseRegCreateForCourseWindow.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\service\SpecialtyService.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\course\CourseCommentPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\common\DocumentSnippet.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\contrib\ContributionPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\service\CourseRegService.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\exam\ExamContributePage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\event2\SocialNetworkEventComponent.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\event2\AuctionEventComponent.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\user\MiniUserList.java,C:\javadev\prj\JavaBlackBelt\src\main\java\be\loop\jbb\bl\impl\QuestionServiceImpl2.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\common\WindowUtil.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\common\PageUtil.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\user\UserPictureUploadWindow.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\question\QuestionHistoryPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\application\BlackBeltApplication.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\search\SearchPanel.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\common\ComponentFactory.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\event2\ExamEventComponent.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\common\UploadComponent.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\parser\BlackBeltTagHandler.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\login\LoginCorner.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\user\UserPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\layout\ChangeBackgroundImageWindow.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\search\SearchDialogBox.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\coursepage\VideoWindow.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\question\QuestionTextLabel.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\exam\ExamPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\course\ConvinceYourBossWindow.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\layout\DeploymentBanner.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\question\QuestionExpandablePanel.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\fintransaction\FinTransactionTable.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\group\GroupInvitationsList.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\service\SectionTextService.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\exam\ExamPerformPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\specialty\SpecialtyPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\coursepage\SectionsOnPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\event2\BeltSuccessEventComponent.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\service\IndexManagerService.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\community\CommunityListPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\service\QuestionImageService.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\question\PreviewQuestionWindow.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\lang\LanguageLeadersPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\service\CourseTodoService.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\coursereg\CourseRegUserPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\post\PostList.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\xml\SaveToXmlLink.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\forum\EditForumPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\coachoffering\CoachOfferingsList.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\course\CourseCommentComponent.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\login\LoginWindow.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\belt\LevelPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\manualverification\ManualVerificationReferenceEditWindow.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\exam\ExamResultPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\forum\MenuNavigationForum.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\topic\TopicLeadersPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\service\InventoryItemService.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\topic\TopicListPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\scheduled\AsynchonousTasksFacade.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\question\EditQuestionWindow.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\user\RanchUserImageAndDescription.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\document\DocumentPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\coach\CoachOfferingPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\service\DiscussionService.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\forum\PostLayout.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\parser\BlackBeltTagHandlerQuestionCodeImageCreation.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\RegisterPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\be\loop\jbb\batch\old\JohnTester.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\exam\UserExamsPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\imageDemo\ImageDemoPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\application\BlackBeltWebApplication.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\forum\DiscussionPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\layout\Header.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\ReactivatePage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\manualverification\ManualVerificationJobAdEditWindow.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\service\TopicReviewerAccessService.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\parser\BlackBeltTagHandlerCourseOnPdf.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\user\UserNickNameEditWindow.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\search\ResultPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\dao\V5QuestionVersionDao.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\coachoffering\CoachOfferingBox.java,C:\javadev\prj\JavaBlackBelt\src\main\java\be\loop\jbb\bl\impl\UserServiceImpl.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\inventory\UserInventoryPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\be\loop\jbb\bl\impl\ContributionServiceImpl.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\event2\QuestionEventComponent.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\auction\CreateEditAuctionWindow.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\event2\DiscussionDetail.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\group\GroupCandidatesList.java,C:\javadev\prj\JavaBlackBelt\src\main\java\be\loop\jbb\web\ww\actions\fragments\LastAuctions.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\coursereg\CourseStatusForUser.java,C:\javadev\prj\JavaBlackBelt\src\main\java\be\loop\jbb\bl\BLFacade.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\coach\CoachStatusBox.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\question\CategoryLine.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\exam\ExamAccessPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\coursepage\Navigation.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\coursereg\CourseRegDetailBox.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\coursepage\CoursePagePage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\user\UserVideoEditWindow.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\event2\EventComponent.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\coursereg\CourseRegTable.java,C:\javadev\prj\JavaBlackBelt\src\main\java\be\loop\jbb\web\ww\actions\ContributionManager.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\HomePage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\event2\NewsEventList.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\auction\AuctionTable.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\service\MailChangeOptionPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\community\CommunityPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\be\loop\jbb\batch\old\NudeMain.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\service\MentorshipService.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\coach\CoachStatusPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\xml\CourseXmlGenerator.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\coursepage\AttachmentWindow.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\group\GroupSmallBox.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\forum\DiscussionListPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\question\MoveQuestionWindow.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\coursepage\SectionComponent.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\service\AuctionService.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\exam\NextButtonPanel.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\coach\AdminPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\question\AnswerLines.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\message\ReportSpamPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\service\InventoryUiService.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\service\GroupService.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\manualverification\ManualVerificationJobAdAcceptWindow.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\exam\ExamObjectivePage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\question\QuestionPanel.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\question\QuestionList.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\question\QuestionListPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\topic\TopicLedList.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\topic\TopicLeaderList.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\auction\AuctionDetail.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\coursepage\CourseAdminPanel.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\parser\BlackBeltTagHandlerStringGenerator.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\manualverification\ManualVerificationVideoAcceptWindow.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\coach\CourseRegDebriefing.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\user\UserColumnGenerator.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\group\GroupListPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\user\PrivilegePage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\service\BeltService.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\coach\MentorshipBox.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\question\CategorySelector2.java,C:\javadev\prj\JavaBlackBelt\src\main\java\be\loop\jbb\web\ww\actions\AuctionEdit.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\question\QuestionPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\common\NotificationUtil.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\manualverification\ManualVerificationWaitingPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\inventory\ActivateItemOnGroupWindow.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\course\SectionTextTable.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\parser\BlackBeltTagHandlerQuestionCodeImageDisplay.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\topic\TopicTempLeaderList.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\forum\ForumCategoryPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\coach\MentorshipPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\topic\TopicWithCourseExamLinks.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\forum\UserDiscussionListPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\event2\CourseRegEventComponent.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\exam\V5QuestionnaireTable.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\coursereg\StudentCourseRegList.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\service\ModerationService.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\common\SmallSeparatedLinks.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\service\ReminderService.java,C:\javadev\prj\JavaBlackBelt\src\main\java\be\loop\jbb\bl\impl\ExamServiceImpl.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\coursepage\CourseToc.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\group\GroupInvitationPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\coach\CoachTopicPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\group\RegisterAndJoinGroupWindow.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\user\UserListPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\lang\TranslationReviewDialog.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\lang\LanguageLedList.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\service\CourseCommentService.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\inventory\InventoryItemActivateOnUserWindow.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\user\UserGrid.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\layout\Footer.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\service\MarketingMailService.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\topic\TopicDescriptionBox.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\event2\GroupEventComponent.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\search\CourseSearchResultsManager.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\pdf\SaveToPDFLink.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\parser\BlackBeltTagHandlerQuestionCodeText.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\event2\CourseTodoEventComponent.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\parser\BlackBeltTagParser.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\course\CourseDeleteWindow.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\group\GroupHierarchyTree.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\RegisterValidatePage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\common\BreadCrumb.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\user\UserBoardPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\group\GroupPanel.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\topic\TopicHomePageBox.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\manualverification\ManualVerificationEditWindow.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\group\GroupsAndUsersPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\layout\Menu.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\specialty\TopicsInSpecialty.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\group\TopGroupsBox.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\pdf\CoursePdfGenerator.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\pdf\PdfCourseOptionWindow.java,C:\javadev\prj\JavaBlackBelt\src\main\java\be\loop\jbb\bl\impl\FileServiceImpl.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\topic\TopicPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\service\LanguageReviewerAccessService.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\lang\CourseLangPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\manualverification\ManualVerificationTable.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\parser\BlackBeltTagHandlerCourse.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\group\GroupMemberList.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\event2\MentorshipEventComponent.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\coursereg\CourseRegPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\forum\ForumEditorLayout.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\coursetodo\CourseTodoPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\application\PageAccessTraceLogInterceptor.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\manualverification\ManualVerificationRequesterPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\forum\DiscussionLayout.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\event2\BadgeEventComponent.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\service\MailSender.java,C:\javadev\prj\JavaBlackBelt\src\main\java\be\loop\jbb\web\ww\actions\BidEdit.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\model\SiteMapGenerator.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\manualverification\ManualVerificationRejectWindow.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\group\UserGroupPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\dao\QuestionVersionDaoImpl.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\service\ManualVerificationService.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\parser\BlackBeltTagHandlerCourseOnBrowser.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\group\GroupPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\course\CourseActivityPage.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\exam\QuestionAnswerStatusGrid.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\inventory\SendItemModalWindow.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\forum\DeletePostWindow.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\coursetodo\CourseTodoEditWindow.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\message\MessageSendWindow.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\user\UserSmallBox.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\coursetodo\CourseTodoList.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\scheduled\AuctionClosingJob.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\parser\BlackBeltTagHandlerLuceneSearch.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\service\MailTemplateService.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\parser\BlackBeltTagHandlerCourseOnXml.java,C:\javadev\prj\JavaBlackBelt\src\main\java\blackbelt\ui\course\CoursePage.java}'
16:15:56 Need to recompile 'CoachOfferingEditWindow.java'
16:15:56 Need to recompile 'GroupPictureUploadWindow.java'
16:15:56 Need to recompile 'QuestionState.java'
16:15:56 Need to recompile 'TopicLinkCommunitySpecialtyWindow.java'
16:15:56 Need to recompile 'FinTransactionPage.java'
16:15:56 Need to recompile 'MultiChoiceModalWindow.java'
16:15:56 Need to recompile 'NewsPage.java'
16:15:56 Need to recompile 'QuestionUserAnswerPanel.java'
16:15:56 Need to recompile 'UserStatusEditWindow.java'
16:15:56 Need to recompile 'V5QuestionnaireService.java'
16:15:56 Need to recompile 'OAuthSiteIntegrationWindow.java'
16:15:56 Need to recompile 'UserSkypeIdEditWindow.java'
16:15:56 Need to recompile 'NewsEditForm.java'
16:15:56 Need to recompile 'GroupEditWindow.java'
16:15:56 Need to recompile 'CategoryEditWindow.java'
16:15:56 Need to recompile 'QuestionDaoImpl.java'
16:15:56 Need to recompile 'DialogUtils.java'
16:15:56 Need to recompile 'SpecialtyEditWindow.java'
16:15:56 Need to recompile 'UserDescriptionEditWindow.java'
16:15:56 Need to recompile 'UserPasswordEditWindow.java'
16:15:56 Need to recompile 'UserCountryEditWindow.java'
16:15:56 Need to recompile 'Menu.java'
16:15:56 Need to recompile 'GroupSelectWindow.java'
16:15:56 Need to recompile 'CourseRegCreateWindow.java'
16:15:56 Need to recompile 'GroupSelectFromListWindow.java'
16:15:56 Need to recompile 'QuestionTask.java'
16:15:56 Need to recompile 'ShowHideInProfileButton.java'
16:15:56 Need to recompile 'RecruitReactivateFriendWindow.java'
16:15:56 Need to recompile 'ReportProblemWindow.java'
16:15:56 Need to recompile 'CourseSearchPage.java'
16:15:56 Need to recompile 'AuctionPage.java'
16:15:56 Need to recompile 'PriceEditWindow.java'
16:15:56 Need to recompile 'V4ToV5DataConvertor.java'
16:15:56 Need to recompile 'CourseRegEditWindow.java'
16:15:56 Need to recompile 'GroupManagersWindow.java'
16:15:56 Need to recompile 'User.java'
16:15:56 Need to recompile 'MentorRequestWindow.java'
16:15:56 Need to recompile 'CoursePriceCalculator.java'
16:15:56 Need to recompile 'MailService.java'
16:15:56 Need to recompile 'CourseEvaluationWindow.java'
16:15:56 Need to recompile 'CategorySelector.java'
16:15:56 Need to recompile 'MentorshipAdminPage.java'
16:15:56 Need to recompile 'ToSortWindow.java'
16:15:56 Need to recompile 'UserSelectWindow.java'
16:15:56 Need to recompile 'NewsEventComponent.java'
16:15:56 Need to recompile 'ClickListenerUtil.java'
16:15:56 Need to recompile 'PostCreateWindow.java'
16:15:56 Need to recompile 'CourseRegApplyCreateWindow.java'
16:15:56 Need to recompile 'CourseRegCancelWindow.java'
16:15:56 Need to recompile 'TestPage.java'
16:15:56 Need to recompile 'CourseRegEndWindow.java'
16:15:56 Need to recompile 'SingleNewsBox.java'
16:15:56 Need to recompile 'Login.java'
16:15:56 Need to recompile 'BlackBeltUriAnalyzer.java'
16:15:56 Need to recompile 'SetAsPrimaryGroupButton.java'
16:15:56 Need to recompile 'ExamEditWindow.java'
16:15:56 Need to recompile 'CourseEvaluationForm.java'
16:15:56 Need to recompile 'UserMailEditWindow.java'
16:15:56 Need to recompile 'RetrieveSocialImageWindow.java'
16:15:56 Need to recompile 'ManualWorkDaoImpl.java'
16:15:56 Need to recompile 'CategoryWithCourseSectionBinderWindow.java'
16:15:56 Need to recompile 'V5ExamService.java'
16:15:56 Need to recompile 'UserNameEditWindow.java'
16:15:56 Need to recompile 'RegistrationForm.java'
16:15:56 Need to recompile 'CoachService.java'
16:15:56 Need to recompile 'CourseRegWindow.java'
16:15:56 Need to recompile 'SocialSiteIntegrationWindow.java'
16:15:56 Need to recompile 'HireCoachWindow.java'
16:15:56 Need to recompile 'ResultView.java'
16:15:56 Need to recompile 'RejectCoachWindow.java'
16:15:56 Need to recompile 'QuestionProposalVoter.java'
16:15:56 Need to recompile 'CourseRegCreateForCoachOfferingWindow.java'
16:15:56 Need to recompile 'TopicLinkPreReqsWindow.java'
16:15:56 Need to recompile 'SpecialtyLinkCommunityWindow.java'
16:15:56 Need to recompile 'CourseRegApplyEditWindow.java'
16:15:56 Need to recompile 'GiveContributionPointsWindow.java'
16:15:56 Need to recompile 'JoinLeaveButton.java'
16:15:56 Need to recompile 'TopicEditWindow.java'
16:15:56 Need to recompile 'UserNameChangeLogWindow.java'
16:15:56 Need to recompile 'InviteUsersToGroupWindow.java'
16:15:56 Need to recompile 'ActiveInventoryItems.java'
16:15:56 Need to recompile 'DeleteDiscussionWindow.java'
16:15:56 Need to recompile 'GroupJoinWindow.java'
16:15:56 Need to recompile 'ExamTopicLinkEdit.java'
16:15:56 Need to recompile 'EventList.java'
16:15:5
Current Time: Mon May 13 06:50:41 GMT 2024
Powered by FUDForum. Page generated in 0.03050 seconds
