Home » Language IDEs » PHP Development Tools (PDT) » Bad Habbits(several small problems, bothering me the whole day)
Bad Habbits [message #676594] |
Sun, 05 June 2011 14:57 |
SaHiB Messages: 5 Registered: May 2011 |
Hi everbody,
i hope, you can help me with some of my "problems". I tried asking in the Newcomer Board, but I was told to try to get answers here, so: here I am
I recently changed from an other editor to eclipse, but there are some of it's habbits which bother me.
I'm using the current Helios version for programming php/html/css/js
- is there any posibility to bind code-templates to a key?
- can I teach eclipse to insert a '<br />' when I'm hitting ctrl+return in html-mode, instead of a linebreak?
- when mixing html and php, I usually use short tags for outputs. When I start typing <? it auto inserts a <?php ?>, so if i want to use shorttags <?=$foo?> this habbit costs a lot of time - can I deactivate it?
- where is the definition list for php keywords stored? I like to have AND/OR also in the keywordlist for syntax highlighting, but don't know where to add it.
- really bothering is that the eclipse viewport jumps, when undoing something. If I hit strg+z, it the last step is undone, but the viewport also jumps, so the line where the undoing action happend "jumps" to line 26 of the visible lines. How can i stop this from happening?
- when I have an IF in php, followed by a single command, I dont use brackets, but intend the command with one tab in the next line. ctrl+i dont recognize this dependency between the command and the IF, so it dont intend the code, that is only executet if the condition is true (same problem with loops)
Example:
if(true)
foo();
//ctrl+i changes it to
if(true)
foo();
- another problem with ctrl+i and with shift-tab, is removing indenting. It works fine, as long a there are tabs used for intending. But as soon as you'll get a file, that uses 4 whitespace instead of one tab (or even mixes whitespace and tabs), it fails. How can I make eclipse, to treat 4 white spaces as one tab, when shifting code to the left?
- when double clicking on code to select a word, some of the selecting habbits of eclipse are not that productiv for me.
Example: foo.class.php - double click on foo should select only foo, but in eclipse the whole string foo.class.php is selected. Same problem with foo/bar. Is there any file where I can edit those "stop selecting" characters ?
- A last thing: I'd like to make some small text-manipulating-custom-scripts running over my Code, like removing whitespaces, changing some chars against others and stuff like that - is there an easy to use interface for userdefinded scripts, where I can access the content of the current editor and modify it, or do I need to programm a whole plugin for those simple tasks?
thats all so far, a lot of questions and I know, my english isn't the best, but I hope you'll understand it anyways. I also searched for all topics with google, but either I use the wrong keywords, or I am the only one, that is bothered by these things.
btw: even a "that is impossible to do" for one ore more of the above questions would be an answer that helps me, so I can stop searching for a solution!
Anyway: thanks for your help and your patience
greetings
SaHiB
Re: Bad Habbits [message #676783 is a reply to message #676594] |
Mon, 06 June 2011 14:03 |
dominik Messages: 122 Registered: July 2009 |
Yes, but You need additional plugin, browse eclipse marketplace for some with
keystroke snippets support.
With additional plugin this should be possible.
preferences -> php -> editor -> typing -> add "php" after PHP start tag
Yes, You can turn off this feature, but it's really bad idea, because You will
get errors from xml declaration etc. I always turn off short tags.
You can assign new template to PHP like "=" what will evaluate to <?=${}?> ->
then single char + ctrl + space and enter will fill this template. It can fill
<?php echo ${} ?> also :)
Somewhere in resources directory. Try to grep for some php function and You will
find that.
I can't understand how You would like this to work.
> Example:
> if(true)
> foo();
> if(true)
> foo();
Just edit "if" template and use it or add something similar to this.
Short notation is great but only for short things:
if (...) ...();
else ..();
Why You want to use short version and waist two lines?
formatters -> indent as tabs, width: 1, text editors -> displayed tab size: 4
BTW: there are plugins to convert mixed content to tabs, also it's great to use
built in formatter (ctrl-shift-f)
Sorry but I never seen any other behavior for this, moreover this can be system
related setting.
Yes, there is plenty of features that can do this trick. I have somewhere code
beautifier that changes whole file on keystroke. You can launch external program
or make small changes.
/dmc
Re: Bad Habbits [message #677136 is a reply to message #676783] |
Tue, 07 June 2011 16:47 |
thx dominic, you are my Hero - thx for a such detailed answer!
but i wouldn't be a noob if I wouldn't have any further questions
If searched the marketplace bevor with several keywords (also for "keystroke snippet") but didn't find anything. Do you have a name of such a plugin for me? The Plugindescriptions in the marketplace are mostly cryptical to me so most of the time I don't understand, what a plugin is really for...
shorttags are usually no problem in my projects and beside the fact, that they are very short, I like the clean look of them. If you get Problems with them a simple earch&replace can solve the problem in the whole project...
Anyway, your hint solved my Problem THX!
I still havent managed to get AND / OR highlighted as a keyword. In the resources I can find all classes ans methods for PHP, but I dont see a way, how that could help me, telling the syntaxhighlighter to treat AND/OR as a keyword.
ctrl-shift-f - yeahh! that's great - it works!
Quote:>Sorry but I never seen any other behavior for this, moreover this can be system
>related setting.
I don't think so. It is depending on the current syntax-highlighter.
PHP Example:
I'm using firePHP to debug like this:
FB::info($bar,'$foo'); doubleclick on $foo selects just foo instead of $foo which it makes harder to relpace it by something else.
Other (HTML) Example:
if I like to replace the files name I doubleClick on foo, but instead of selecting 'foo' it selects upload/gfx/foo.png.
<img src="upload/gfx/foo.png" alt="bar" />
Same situation, but within PHP Code will select foo.png which is much better.
echo '<img src="upload/gfx/foo.png" alt="bar" />';
Anyway: there seems to be a definition of "stop characters" for each language and I like to know, where I can find these definitions
Thy angain for your detailed post bevore, it has been already a great help!
Re: Bad Habbits [message #683781 is a reply to message #677136] |
Tue, 14 June 2011 12:17 |
First plugin by snippets keyword:
http://market.eclipsesource.com/yoxos/node/AfaeFeature.feature.group?mpc=true&mpc_state=
Afae stands for Another Freebooter's All-purpose Editor. It is
a group of plugins for Eclipse that do the following:
- Syntax highlighting for many types of files.
- MetaWeblog plugin for posting to your blog
- Keystroke comments
- An image viewer and basic re-sizer for GIF, JPG, ICO, and PNG
- Snippets inserter with trigger text and variable replacement.
- A while-you-edit XML DTD and XML Schema validator
- Much more...
Try it, it should be what You are looking for.
Short tags are always problematic, but it's Your choice.
I used that few years ago when all I have was simple notepad and before xml like
files were commonly used.
Ok, just try plugin mentioned. It have: Syntax highlighting for many types of
files. - maybe this will work for You, if not I'm sure that You can find more
plugins with this.
Yes, this is nice, particularly for very old code that need refactoring. You can
customize every construction how it's changed.
>> related setting.
> PHP Example:
> echo '<img src="upload/gfx/foo.png" alt="bar" />'; Anyway: there seems to be a
I really never paid much attention for this behavior but sure, eclipse allows to
change double click strategy, even for each type of file. Here You can read more
about that:
http://wiki.eclipse.org/FAQ_How_do_I_change_the_selection_on_a_double-click_in_my_editor%3F
best regards
/dmc
Current Time: Sat Apr 27 20:31:22 GMT 2024
Powered by FUDForum. Page generated in 0.04198 seconds
