Re: Cheat sheets and Properties dialog [message #661423 is a reply to message #660825] |
Thu, 24 March 2011 15:26 |
Originally posted by: eclipse.bugzilla.post.gmail.com
What causes the cheat sheet to be able to "follow" some dialogs (show in
tray of the dialog) and not others? Is it the way the dialog is coded, the
way the command to invoke the dialog is coded, or the way the cheat sheet is
written (assuming that the dialog=true attribute is set)?
Mary
Re: Cheat sheets and Properties dialog [message #661663 is a reply to message #661488] |
Fri, 25 March 2011 19:33 |
Makes sense.
The command to bring up the Properties dialog does not work from a cheat
sheet. Probably because there is no selection, so it does not know which
Properties to show?
"Chris Goldthorpe" <cgold@us.ibm.com> wrote in message
news:imgeel$3jl$1@news.eclipse.org...
> There are three conditions that all have to be true for the tray
> containing a cheatsheet to be opened at the right hand side of a dialog.
> 1. The dialog is opened from a cheat sheet using a command.
> 2. The <item> in the cheat sheet has dialog="true" 3. The dialog class
> must be a subclass of TrayDialog ( you can tell because there is a button
> with a question mark at the lower left ).
FUDForum. Page generated in 0.03424 seconds
