Re: Plugin does not seem to start when running exported product [message #653843 is a reply to message #653806] |
Fri, 11 February 2011 13:39 |
Ivan Larionov Messages: 37 Registered: July 2009 |
Member |
Hi Tom,
Yes! You are absolutely right. I added it in the build.properties and
everything started working.
The platform hadn't recognized the bundle as a plug-in, I suppose.
Thank you very much.
Ivan
On 11.02.2011 12:01, Tom Schindl wrote:
> Is the plugin.xml part of your build.properties?
> Tom
> Am 11.02.11 10:07, schrieb Ivan Larionov:
>> Hi Everyone,
>> I would be grateful if someone could help me with the following issue:
>> I made two plugins A and B. B defines an application and A just makes
>> contributions in the UI. I exported these plugins as an RCP product.
>> When I ran the exported product, the application started and everything
>> seemed fine except that there were no UI extensions made by the plugin
>> A. Later, when I tried to elaborate in the console with the help of 'ss'
>> command I found out that the A plugin had not started at all. My further
>> attempts to set @start option in the config.ini for the plugin A did not
>> lead to any success. Everything starts just fine when running from the
>> IDE using launch configuration. But in exported product it doesn't.
>> Would anybody suggest what might be problematic?
>> Thanks,
>> Ivan
FUDForum. Page generated in 0.04047 seconds
