How to change wrap column for "source format" operation? [message #649732] |
Thu, 20 January 2011 13:30 |
Ben Stover Messages: 108 Registered: January 2010 |
As well known I can re-format the marked part of the current source code be clicking the menu
Source->Format
Unfortunately some (long) source lines are wrapped very
short.
How can I specify (increase) the column number when I source code line wrap should take place?
BTW: Is this source->format a pure (=built-in) feature of Eclipse or does is depend from CheckStyle Plugin settings?
If there are two different line length wrap values:
Which has priority?
Ben
Re: How to change wrap column for "source format" operation? [message #649744 is a reply to message #649732] |
Thu, 20 January 2011 14:09 |
shanky sohar Messages: 13 Registered: January 2011 |
Junior Member |
Window->preferences->java->code style->Formattor
here the active profile you will see is Eclipse[build-in]
click on edit
you will get eclipse[build-in] profile settings
Got o line-wrapping
here Maximum-line-width is 80 by default..
change "Maximum-line-width" to whatever you want.
there is need to change the name of the profile also..
Change the profile name and say APPLY
select the active profile as the same name which you have given
and now format your file by saying source format
[Updated on: Thu, 20 January 2011 14:09] Report message to a moderator
FUDForum. Page generated in 0.02957 seconds
