Home » Language IDEs » Java Development Tools (JDT) » ASTRewrite.replace() and ASTRewrite.createGroupNode()
ASTRewrite.replace() and ASTRewrite.createGroupNode() [message #648380] Wed, 12 January 2011 11:25 Go to next message
Jochen Huck is currently offline Jochen Huck
I want to perform some source code transformations using the class ASTRewrite. I want to insert some ASTNodes (lets say n1, n2, n3) after a known ASTNode (denoted by n) . I could do this with a ListRewrite if the ASTNode n was always in a Block or something like that. But I don't like this assumption and therefore I am searching for another possibility. Currently I am grouping the ASTNodes to a single node n0 with
ASTNode[] nodes = {n, n1, n2, n3};
n=ASTRewrite.createGroupNode(nodes);
Afterwards I replace the node n through n0 with
ASTRewrite.replace(n, n0, null);
That works fine for me in most cases. But sometimes there are nodes missing after the transformation (I do many of these in one CompilationUnit). I assume that the problem has to do with the grouped nodes. Can someone help me?
Jochen
Re: ASTRewrite.replace() and ASTRewrite.createGroupNode() [message #649237 is a reply to message #648380] Tue, 18 January 2011 05:31 Go to previous message
Satyam Kandula is currently offline Satyam Kandula
Can you give a testcase?
Previous Topic:Diff PackageExplorer and ProjectExplorer?
Next Topic:Possible to show java.util.concurrent locks in Debug view?
Current Time: Mon May 20 12:21:29 EDT 2013
Powered by FUDForum. Page generated in 0.01453 seconds
