Home » Language IDEs » Java Development Tools (JDT) » Linking Working Set
Linking Working Set [message #644290] Fri, 10 December 2010 07:24 Go to next message
Mike Dundee is currently offline Mike Dundee
is it possible to link Working Set in "Project Explorer" and dialogs like "Open Type" or "Open Resource" ?
I can specify Working Set in any of the 3 mentioned. However it does not affect selected working set in other places.
For example, when I select working set in "Project Explorer", I have to select it again in both dialogs, which is quite uncomfortable...
Thanks for response
Re: Linking Working Set [message #644298 is a reply to message #644290] Fri, 10 December 2010 07:42 Go to previous message
Deepak Azad is currently offline Deepak Azad
On 12/10/2010 5:54 PM, Mike Dundee wrote:
> Hello,
> Thanks for response
No this is not possible yet. You could open a bug against JDT/UI.
Previous Topic:Verify Launch Attributes...
Next Topic:Why does eclipse try to compile all other open projects when I run a unit test
Current Time: Wed May 22 07:00:27 EDT 2013
Powered by FUDForum. Page generated in 0.01389 seconds
