Re: Problem with Tabbed Properties View [message #641452] |
Thu, 25 November 2010 13:58 |
Udo Walker Messages: 81 Registered: July 2009 |
Member |
do you still have a problem with the tabbed properties view in your RCP app?
I maybe had the same problem today, too. I found out that I cached my
subclass of TabbedPropertySheetPage in my editor. When I closed the
property view and opened it again then I got the NPE you described.
After I changed the initialisation of the page so that it is always
created a new instance each time the framework calls my adapter then the
NPE is gone and there is no problem anymore to close/open the properties
view.
With regards
Udo
Am 02.01.2008 16:51, schrieb Sakis Kotisis:
> You are right. I tried out the example in a clean installation of
> Eclipse and couldn't reproduce the error. It seems there is something i
> do (or don't) in the rest of my RCP app which causes the error. I
> changed from my custom made perspective to the Java perspective and
> couldn't reproduce it. Then changed it back again and the error vanished
> ever since. I'm at a loss here and totally clueless as to what happened.
> I'm going to freeze the issue for now and post any new findings for
> future reference. Thanks for your help.
FUDForum. Page generated in 0.03468 seconds
