v2.2.1: PHP Executable SAPI Type cannot be saved [message #637605] |
Sun, 07 November 2010 18:30 |
Andras Janurik Messages: 3 Registered: July 2009 |
Junior Member |
Since upgrading PDT from 2.2 to version: 2.2.1.v20101001-2300 (called M201010110334 in downloads) I am experiencing a problem of saving the SAPI Type for a PHP Executable.
After I save it and click edit again the combo is just blank.
It works fine with previous versions.
Anyone else encountered it?
The problem is that, since the PHP Executable configuration is not correct, I cannot run php files as script.
I get this message in console:
You cannot use both -n and -c switch. Use -h for help.
I filed a bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=329630
I workaround would appreciated.
[Updated on: Mon, 08 November 2010 17:38] Report message to a moderator
FUDForum. Page generated in 0.02971 seconds
