Home » Eclipse Projects » Eclipse 4 » XWT: DataContext change --> Change UI
XWT: DataContext change --> Change UI [message #636167] Fri, 29 October 2010 10:07 Go to next message
I have a XWT file UI description, containing a button btn1. It's a simple example of my aim.
<Composite xmlns="http://www.eclipse.org/xwt/presentation"
	xmlns:x="http://www.eclipse.org/xwt" xmlns:css="http://www.eclipse.org/css"
	xmlns:c="clr-namespace:myproject.ui" xmlns:j="clr-namespace:myproject.ui"
	x:Class="myproject.ui.Essai" >
	<Composite.layout>
		<GridLayout numColumns="2" />
	</Composite.layout>
	<Composite.layoutData>
		<GridData grabExcessHorizontalSpace="true"
			horizontalAlignment="SWT.FILL" />
	</Composite.layoutData>
	<Label text="Name" css:id="LabelUnBold"></Label>
	<Text name="name"
		text="{Binding path=name, updateSourceTrigger=PropertyChanged}">
		<Text.layoutData>
			<GridData grabExcessHorizontalSpace="true" widthHint="150"
				horizontalIndent="40" />
		</Text.layoutData>
	</Text>
	<Button name="btn" text="btn1" selectionEvent="changeFirstNamet"></Button>
	<Button name="btn" text="btn2"></Button>
	<Label text="Firstname" css:id="LabelUnBold"></Label>
	<Text name="firstName"
		text="{Binding path=firstName, updateSourceTrigger=PropertyChanged}">
		<Text.layoutData>
		</Text.layoutData>
	</Text>
	<Label text="Namet" css:id="LabelUnBold"></Label>
	<Text name="namet" text="{Binding path=name}">
		<Text.layoutData>
		</Text.layoutData>
	</Text>
	<Label text="Firstnamet" css:id="LabelUnBold"></Label>
	<Text name="firstNamet" text="{Binding path=firstName,updateSourceTrigger=PropertyChanged}">
		<Text.layoutData>
		</Text.layoutData>
	</Text>
</Composite>
On clicking on th button btn1, an event is called in the java class in order to change a value of the datacontext.
public class Essai extends Composite{
     * @param _parent
     * @param _style
    public Essai(Composite _parent, int _style) {
        super(_parent, _style);
    public void changeFirstNamet(Event _event){
        Person data = (Person)XWT.getDataContext(this);
        data.setFirstName("hello");
On clicking on the btn1 button, this value (hello) must be displayed in the firstNamet widget (and firstName too) in the xwt file (a Text). But it doesn't work.
Why ?
Thank you.
Re: XWT: DataContext change --> Change UI [message #636693 is a reply to message #636167] Tue, 02 November 2010 09:35 Go to previous message
I found a solution. A lot of people saw my question, so I give you the solution that can help someone.
In the Essai class, I add:
     * @param _parent
     * @param _style
       // data.setFirstName("hello"); not used now
        IObservable obs = XWT.findObservableValue(this, data, "firstName");  //"firstName" is an attribute of Person
        obs.setValue("TheNewFirstname");
The last parameter of findObservableValue can be a composite object (for example: Company class that contains an adress as String).
If the adress is displayed in the XWT like
<Text text="{Binding path=company.adress}">
it will be updated.
Previous Topic:Dynamically creating Parts (updated from the E4/Snippets) / Passing around IEclipseContext
Next Topic:RCP (Eclipse 3.6) into E4
Current Time: Sun Jul 06 20:46:34 EDT 2025
Powered by FUDForum. Page generated in 0.12871 seconds
