remote extension - is it supported by r-OSGi? [message #624630] |
Mon, 15 December 2008 15:52 |
Marton Sigmond Messages: 73 Registered: July 2009 Location: Hungary |
Member |
there is a extension-point in module #1, and a corresponding extension in
module #2.
As long as I deploy the two modules into the same OSGi container I am good
to go.
But what about deploying them into two different OSGi containers that can
communicate to each other?
Does ECF support this kind of cooperation?
What I mean here:
There is an OSGi server having mudule #2 deployed.
When you start your Eclipse RCP application
- ECF connects to the server
- queries its extension registry for the extensions of our
extension-point
- creates proxy object instances for the remote ones
- registers the found extensions into the local extension registry
- and from this point there is no difference between a remote and a
local extension...
Is it possible with ECF?
Marton
Best Regards,
Marton Sigmond
Senior Software Engineer
FUDForum. Page generated in 0.02740 seconds
