New to UML2tools & existing Java project [message #624569] |
Thu, 09 July 2009 16:26 |
(environment: Windows XP Pro w/ Galileo)
I've just downloaded the Modeling Framework plugin and began messing
around w/ it:
I have an existing web application project w/ a lot of .java files under a
particular package. I've created a folder called UML under the project and
in there have chosen to create a Class diagram. Per the UML 2.1 Diagrams
wizard I choose Class Diagram & it creates the my_class_diagram.uml and
my_class_diagram.umlclass files. Working w/ the .umlclass I can manually
add Class elements from the Palette and make associations/generalization,
etc just to get myself familiar w/ the uml2tool environment.
I haven't found out how to do the following:
1. Does UML2tools support creating a new .umlclass/.uml file and allow me
to drag and drop existing .java files into the .umlclass's tab to start
creating the Class diagram?
2. Similarly, how does one associate (create) a sequence diagram given the
existing package and its .java files?
I've found a couple of tutorials about creating the Class diagrams but
none that explain the above issues that I'm having.
Thanks, Jim
FUDForum. Page generated in 0.03938 seconds
