Viewing element tagged values on Properties tab when viewing UML (class) diagram? [message #619826] |
Tue, 27 May 2008 13:34 |
Originally posted by: ebadgley.mitre.org
Greetings,
I'm working on a project that involves a custom profile and tagged value
set, and I've noticed that after I've created a Class Diagram (manually), I
don't see the tagged values on the Properties tab when I select a class (or
other element) on the diagram editor. I do see the default "UML" property
set (Name, Owned Port, etc. etc. etc.) on the Core tab, but I don't see the
additional properties/tagged values associated with the stereotype of that
element, as I do when highlighting the same element in the UML Editor tree.
Is this a capability that is missing from the UML2 Diagram editor at
present, or could I be doing something incorrectly? I do know that the
stereotypes are correctly applied to the elements and as long as I stick to
the UML2 Editor, I can see/manipulate them just fine (plus they carry over
when exporting the .uml file to another tool we are using). (I'd also be
interested to know if anyone has extended the Diagram Editor to add this
capability.)
Ellen Badgley
FUDForum. Page generated in 0.02544 seconds
