Resigning org.eclipse.core.filesystem [message #601400] |
Wed, 09 September 2009 20:19 |
No real name Messages: 2 Registered: September 2009 |
Junior Member |
Ant Task:
<eclipse.jarProcessor jar=" ${plugin.path}/org.eclipse.core.filesystem_1.2.0_v20080604-1 400.jar "
sign="true" keystore="${sign.keystore}" alias="${sign.alias}" storepass="${sign.storepass}"
unsign="true" verbose="true" />
stacktrace:
[java] [eclipse.jarProcessor] java.io.FileNotFoundException
[java] [eclipse.jarProcessor] at org.eclipse.update.internal.jarprocessor.JarProcessorExecuto r.process(JarProcessorExecutor.java:93)
[java] [eclipse.jarProcessor] at org.eclipse.update.internal.jarprocessor.JarProcessorExecuto r.runJarProcessor(JarProcessorExecutor.java:83)
[java] [eclipse.jarProcessor] at org.eclipse.pde.internal.build.jarprocessor.JarProcessorTask .execute(JarProcessorTask.java:93)
[java] [eclipse.jarProcessor] at org.apache.tools.ant.UnknownElement.execute(UnknownElement.j ava:288)
[java] [eclipse.jarProcessor] at sun.reflect.GeneratedMethodAccessor4.invoke(Unknown Source)
[java] [eclipse.jarProcessor] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
[java] [eclipse.jarProcessor] at java.lang.reflect.Method.invoke(Method.java:585)
[java] [eclipse.jarProcessor] at org.apache.tools.ant.dispatch.DispatchUtils.execute(Dispatch Utils.java:105)
[java] [eclipse.jarProcessor] at org.apache.tools.ant.Task.perform(Task.java:348)
[java] [eclipse.jarProcessor] at org.apache.tools.ant.Target.execute(Target.java:357)
[java] [eclipse.jarProcessor] at org.apache.tools.ant.Target.performTasks(Target.java:385)
[java] [eclipse.jarProcessor] at org.apache.tools.ant.Project.executeSortedTargets(Project.ja va:1329)
[java] [eclipse.jarProcessor] at org.apache.tools.ant.Project.executeTarget(Project.java:1298 )
[java] [eclipse.jarProcessor] at org.apache.tools.ant.helper.DefaultExecutor.executeTargets(D efaultExecutor.java:41)
[java] [eclipse.jarProcessor] at org.eclipse.ant.internal.core.ant.EclipseDefaultExecutor.exe cuteTargets(EclipseDefaultExecutor.java:32)
[java] [eclipse.jarProcessor] at org.apache.tools.ant.Project.executeTargets(Project.java:118 1)
[java] [eclipse.jarProcessor] at org.eclipse.ant.internal.core.ant.InternalAntRunner.run(Inte rnalAntRunner.java:623)
[java] [eclipse.jarProcessor] at org.eclipse.ant.internal.core.ant.InternalAntRunner.run(Inte rnalAntRunner.java:495)
[java] [eclipse.jarProcessor] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
[java] [eclipse.jarProcessor] at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
[java] [eclipse.jarProcessor] at org.eclipse.ant.core.AntRunner.run(AntRunner.java:513)
[java] [eclipse.jarProcessor] at org.eclipse.ant.core.AntRunner.start(AntRunner.java:600)
[java] [eclipse.jarProcessor] at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
[java] [eclipse.jarProcessor] at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
[java] [eclipse.jarProcessor] at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
[java] [eclipse.jarProcessor] at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
[java] [eclipse.jarProcessor] at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
[java] [eclipse.jarProcessor] at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
[java] [eclipse.jarProcessor] at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
[java] [eclipse.jarProcessor] at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
[java] [eclipse.jarProcessor] at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
FUDForum. Page generated in 0.02770 seconds
