test 11746 to a local freebxml (OMAR) repository [message #588102] |
Mon, 15 December 2008 18:53 |
Bob Messages: 7 Registered: July 2009 |
Hi I'm hoping someone here can help :)
I setup a local repository which is listening at
http://localhost:8080/omar/registry/soap
When I run the JUNIT test 11746, I get the following:
org.eclipse.ohf.ihe.common.ws.OHFSOAPException: Error Sending SOAP
Message. [Caused by org.apache.axis2.AxisFault]
at
org.eclipse.ohf.ihe.common.ws.AbstractOHFSOAPSender.executeS end(AbstractOHFSOAPSender.java:251)
at
org.eclipse.ohf.ihe.common.ws.AbstractOHFSOAPSender.send(Abs tractOHFSOAPSender.java:363)
at
org.eclipse.ohf.ihe.common.ws.AbstractOHFSOAPSender.send(Abs tractOHFSOAPSender.java:384)
at
org.eclipse.ohf.ihe.xds.soap.AbstractXDSSoapClient.send(Abst ractXDSSoapClient.java:148)
at
org.eclipse.ohf.ihe.xds.soap.AbstractXDSSoapClient.send(Abst ractXDSSoapClient.java:104)
at org.eclipse.ohf.ihe.xds.source.Source.submit(Source.java:193 )
at SubmitTest.test1Submission(SubmitTest.java:139)
at junit.framework.TestCase.runTest(TestCase.java:164)
at junit.framework.TestCase.runBare(TestCase.java:130)
at junit.framework.TestResult$1.protect(TestResult.java:106)
at junit.framework.TestResult.runProtected(TestResult.java:124)
at junit.framework.TestResult.run(TestResult.java:109)
at junit.framework.TestCase.run(TestCase.java:120)
at junit.framework.TestSuite.runTest(TestSuite.java:230)
at junit.framework.TestSuite.run(TestSuite.java:225)
at
org.eclipse.jdt.internal.junit.runner.junit3.JUnit3TestRefer ence.run(JUnit3TestReference.java:130)
at
org.eclipse.jdt.internal.junit.runner.TestExecution.run(Test Execution.java:38)
at
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:460)
at
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:673)
at
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(R emoteTestRunner.java:386)
at
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main( RemoteTestRunner.java:196)
Caused by: org.apache.axis2.AxisFault
at org.apache.axis2.AxisFault.makeFault(AxisFault.java:417)
at
org.apache.axis2.transport.TransportUtils.createSOAPMessage( TransportUtils.java:89)
at
org.apache.axis2.description.OutInAxisOperationClient.handle Response(OutInAxisOperation.java:326)
at
org.apache.axis2.description.OutInAxisOperationClient.send(O utInAxisOperation.java:389)
at
org.apache.axis2.description.OutInAxisOperationClient.execut eImpl(OutInAxisOperation.java:211)
at
org.apache.axis2.client.OperationClient.execute(OperationCli ent.java:163)
at
org.eclipse.ohf.ihe.common.ws.AbstractOHFSOAPSender.executeS end(AbstractOHFSOAPSender.java:244)
... 24 more
at
org.apache.axis2.transport.TransportUtils.createDocumentElem ent(TransportUtils.java:156)
at
org.apache.axis2.transport.TransportUtils.createSOAPMessage( TransportUtils.java:111)
at
org.apache.axis2.transport.TransportUtils.createSOAPMessage( TransportUtils.java:87)
... 29 more
The tomcat log spits out an error:
ebxmlrr-soap-receiver-servlet threw exception
javax.servlet.ServletException: SOAP POST failed Unable to internalize
message at
org.freebxml.omar.server.interfaces.common.SOAPServlet.doPos t(SOAPservlet.java:219)
Any help would be appreciated~!
FUDForum. Page generated in 0.02467 seconds
